Post by RESET_9999 » Wed Apr 23, 2025 4:52 pm
deadchip12 wrote: Wed Apr 23, 2025 4:39 pm Not pc gaming though.
Yeah, I don't play games. The HDR10 banding on my C2 isn't too distracting; I have to look pretty closely to notice it.
The posterization during fade-ins and fade-outs, on the other hand, looks really bad, and the uniformity isn't great either: I can see vertical bars in dark content.
Ordered the new 2500-nit LG 77'' G5 yesterday and should arrive on the 29th, so I'm hoping it performs better.
dom61
Post by dom61 » Wed Apr 23, 2025 4:56 pm
RESET_9999 wrote: Wed Apr 23, 2025 4:52 pm ....
Hi Reset
Is the pedestal included or do you get the wall bracket?
I am also interested in the 77 but the pedestal I have to buy separately.
Ugoos AM6B Plus | Remote control G20S PRO Plus | Splitter HDMI HDFury AVR-KEY | Display LG 65B6V | Cables HDMI KabelDirekt Pro series | Audio processor Yamaha RX-V775 | Rotel RMB-1075 | Storage Qnap Ts-431K +TL-D800C |
My PC Ryzen 7950X
Post by RESET_9999 » Wed Apr 23, 2025 5:03 pm
dom61 wrote: Wed Apr 23, 2025 4:56 pm
Hi Reset
I'm using this stand for my 77" C2, which is now going into my bedroom, so I ordered another one for the new TV.
https://www.amazon.ca/dp/B07ZYWXC56?ref ... title&th=1
dom61
Post by dom61 » Wed Apr 23, 2025 5:07 pm
RESET_9999 wrote: Wed Apr 23, 2025 5:03 pm I'm using this stand for my 77" C2, which is now going into my bedroom, so I ordered another one for the new TV.
This is the model from LG
https://www.lg.com/au/tv-accessories/st-g4wr8377/
https://www.amazon.it/LG-Suporte-Stand- ... 674c20ab35
My PC Ryzen 7950X
staknhalo
Post by staknhalo » Wed Apr 23, 2025 11:16 pm
RESET_9999 wrote: Tue Apr 22, 2025 10:52 am Yeah, I'm hearing the same from the G5. It's a good thing we can generate DV for everything.
www.imgur.com/sm2o7Ps.gif
Hopefully the game is good enough you don't get bored and have to pixel peep lol
Also just FYI Auto HDR on Win 11 will work with any DX 10+ game basically and you can adjust it on a per game basis and it remembers settings per game - adds a lot of HDR content if you got a library of games
Post by RESET_9999 » Thu Apr 24, 2025 12:10 am
Not sure if this also affect games but Win11 HDR10 has crushed black. Madvr passthrough, Native app, Nvidia API, Windows native API, all crushed around 70.
SDR Win11 and Win10 HDR10/SDR are fine.
https://drive.google.com/file/d/1_XKu0W ... drive_link
It was reported 2 years ago and it is still an issue: https://www.reddit.com/r/htpc/comments/ ... post_embed
staknhalo
Post by staknhalo » Thu Apr 24, 2025 4:31 am
RESET_9999 wrote: Thu Apr 24, 2025 12:10 am Not sure if this also affect games but Win11 HDR10 has crushed black. Madvr passthrough, Native app, Nvidia API, Windows native API, all crushed around 70.
Typical Microsoft. A lot of crap that sucks about Windows 11 and HDR on the PC platform in general. But I'm locked in with a 20+ year Steam backlog on Windows until they can get Steam OS to run all the same games at least or something.
LV8HD
Post by LV8HD » Fri Apr 25, 2025 10:36 am
@RESET_9999 is this injectable in your opinion?
https://slow.pics/c/nVcUDC1f
Post by RESET_9999 » Fri Apr 25, 2025 11:00 am
No doesnt look like it.
deadchip12
Post by deadchip12 » Fri Apr 25, 2025 4:43 pm
@RESET9999
Do you mind checking A Complete Unknown (2024)? It seems the movie crushes blacks heavy. I tried raising the brightness slider on my a95l from the default 50 to 51 and a lot of shadow details became visible, but that surely was not the right way to do it.
Is there a dolby vision test pattern to test black crush?
Post by RESET_9999 » Fri Apr 25, 2025 4:55 pm
I haven't watched it, but if you restore CMv4.0, it shouldn't be more crushed than HDR10. The movie is 99.99% under 500 nits, but the trim does have a couple of shots that get darker because of the slope adjustments. If I recall correctly, your TV has a target higher than 1000 nits, so that won't affect you because the RPU MDL is 1000 nits.
black crush test files:
https://drive.google.com/drive/u/1/fold ... uQRVdsXINM
Post by RESET_9999 » Sat Apr 26, 2025 3:05 am
RESET_9999 wrote: Sat Dec 30, 2023 5:36 pm mmm. Interestingly, the Windows Movies and TV app has the same red push bug as the Shield. It also has exactly the same blue banding with the ''Multi'' pattern.
mp4 files that works in windows app: https://drive.google.com/drive/folders/ ... drive_link
and this app can play DV in HDR10. Support mkv/ts/mp4 and lossless audio. Also cmv4.0 and L5 and ST P7.. Now that we have two player on windows capable of dynamic metadata, its very easy to compare two sources.
https://apps.microsoft.com/detail/9P9ZH ... n-ms&gl=MS
I just noticed that Windows 11 doesn't have the red push bug when using the Energy player in LLDV-HDR10 mode: only my Windows 10 PC does. This red push issue is directly related to the blue ramp banding seen in the Spears & Munsil color space pattern. I remember noticing the same banding on the Shield.
SM colorspace pattern: https://drive.google.com/file/d/1OhnEb_ ... drive_link
red push samples: https://drive.google.com/drive/folders/ ... drive_link
Explanation of the SM ramps:
https://spearsandmunsil.com/portfolio-i ... r-space-3/
A “ramp” is a smooth gradient of color or gray that goes from one color to another or one level to another as you move across or down the screen. There are six ramps on the Color Space Evaluation pattern: two vertical ramps on each side (one luma and one chroma per side), and two horizontal red and blue ramps just above and below the chroma alignment patterns.
Each of the ramps should look smooth and even, with no bands or streaks anywhere along it. The two ramps in the center should not have a wide solid colored area in the center, but should vary from black to full red or blue at a thin peak in the center and back to black.
If you see really large streaks and wildly varying levels in the ramp, that’s a sign that either your black level isn’t set quite right, or that the device doing the color conversion is prematurely clipping channels, or that it isn’t doing the Y’CbCr->RGB conversion correctly.
deadchip12
Post by deadchip12 » Sat Apr 26, 2025 2:42 pm
RESET_9999 wrote: Fri Apr 25, 2025 4:55 pm I haven't watched it, but if you restore CMv4.0, it shouldn't be more crushed than HDR10. The movie is 99.99% under 500 nits, but the trim does have a couple of shots that get darker because of the slope adjustments. If I recall correctly, your TV has a target higher than 1000 nits, so that won't affect you because the RPU MDL is 1000 nits.
Just used your files to test black crush.
SDR looked the most accurate—I could see all the flashing bars up to 65 from my seat (1.2m from the 65-inch TV). HDR10 crushed blacks more; in order to see the 65 bar, I had to move my face closer to the screen.
Dolby Vision was by far the worst—I could barely see past the 90 bar.
Then, I realized why. A few months ago, an update caused black screens in Dolby Vision to no longer appear as true black. Based on recommendations from forum users, I lowered the RGB-Bias to -4 in the advanced color settings to counteract this. When I raised it back from -4 to 0, I could see the bars up to 67 if I moved closer to the screen. So, it still crushes blacks more than HDR10 but is better. The problem is that black is no longer true black again.
Do you have any solutions for this?
Post by RESET_9999 » Sat Apr 26, 2025 4:05 pm
deadchip12 wrote: Sat Apr 26, 2025 2:42 pm Just used your files to test black crush.
If you can see 65 flashing from a normal viewing distance, your SDR black levels might be slightly lifted. If I'm not mistaken, you should see 66–67 flashing from a normal distance, and 65 only when looking about one foot away from the screen. Of course, all of this is in a dark room without lights.
As for the DV black crush, I have two TVs (cheap hisense and C2) and there is only black crush in cmv2.9.
cmv4.0 is good and the same as HDR10/SDR and my C2 RGB white balance is -2/-2/-2 to achieve perfect black in DV. This doesn't affect the black clipping at all for me.
Also, cmv2.9 is more crushed depending on MDL: 10 000 ­> 4 000 > 1 000
I've been reading a lot about TVs lately because I'm upgrading mine and I heard very often that Sony DV implementation is not very good so you might be better off watching HDR10.
daffie
Post by daffie » Sun Apr 27, 2025 10:21 pm
RESET_9999 wrote: Sat Apr 26, 2025 4:05 pm
Wrong.
Bar 64 is reference black. Bar 64 and everything below it should be black. Bar 65 and 66 should also be impossible to see it flashing. The first visible bar should be 67. But barely with your nose on the screen. This is all written down in the Calman calibration guide you can find on the Internet.
LG OLED65G1RLA / Samsung HW-Q990D / Panasonic UB820 / Ugoos AM6B+ (CE with avdvplus Build)
