Pioneer BDR-UD03 UHD possibility
jws73
Re: Pioneer BDR-UD03 UHD possibility
Post by jws73 »
Hi Coopervid
I also have the BDR-UD03 and would love your help. My info is the following:
OS device name: E:
Manufacturer: PIONEER
Product: BD-RW BDR-UD03
Revision: 1.11
Serial number: SCDL217091WL
Firmware date: 2018-11-28
Drive platform: RS8511
Firmware version: 1.11
Thank you!
jws73 wrote:
Wed Apr 09, 2025 1:24 am
Hi Coopervid
OS device name: E:
Revision: 1.11
Thank you!
PM sent.
Supcool
Post by Supcool »
Hi Everyone
I also got BDR-UD03 and is also interested if it possible for it to read uhd disks
Here info about my current drive
OS device name: E:
Revision: 1.14
Serial number: [redacted]
Firmware date: 2020-06-15
Highest AACS version: 70
Firmware version: 1.14
Thank you by the way for anyone who tries to help
Supcool wrote:
Sat Apr 12, 2025 4:49 am
Hi Everyone
OS device name: E:
Revision: 1.14
sure email me see email below
Supcool
Post by Supcool »
Billycar11 wrote:
Sat Apr 12, 2025 8:12 am
Hi Everyone
OS device name: E:
Revision: 1.14
Already sent you a email thank you
Litzner
Post by Litzner »
I have 2 of these drivers.
Revision: 1.14
Serial number: ...
Revision: 1.14
Serial number: ...
Are these flash-able?
Litzner wrote:
Sun Apr 13, 2025 6:05 pm
Revision: 1.14
Serial number: ...
Revision: 1.14
Serial number: ...
Yeah send me an email for the flasher see below
Supcool
Post by Supcool »
Supcool wrote:
Sat Apr 12, 2025 9:21 am
Hi Everyone
OS device name: E:
Revision: 1.14
Just replied check your email
pyramid4045
Post by pyramid4045 »
Hi Coopervid
OS device name: G:
Revision: 1.21
Serial number: ...
Firmware date: 2018-04-26
Highest AACS version: 81
Firmware version: ID19
Thank you!
sanjay
Post by sanjay »
Hello Coopervid,
I thought I will try my luck with the local staples that had some Verbatim 43890.
I thought perhaps they might have some old stock.
I was right, I just picked one up and it's showing as Pioneer UD03
It would be great if you can help me also as you have helped so many with flashing this drive.
I will be checking for a PM.
Thanks,
very much
pyramid4045 wrote:
Mon Apr 21, 2025 3:02 pm
Hi Coopervid
OS device name: G:
Revision: 1.21
Serial number: ...
Thank you!
Check your PM.
sanjay wrote:
Wed Apr 23, 2025 1:41 am
Hello Coopervid,
Thanks,
very much
Check your PM.
artvandelay
Post by artvandelay »
Hello!
I was just about to buy a new drive and then stumbled onto this thread, which suggests that I can make my BDR-UD03 read UHD discs. Is this possible? I am a Mac user.
Revision: 1.14
Serial number:
Highest AACS version: 19
artvandelay wrote:
Wed Apr 23, 2025 12:51 pm
Hello!
Revision: 1.14
Serial number:
You need a Windows PC or a good Windows VM to flash your drive. let me know.
artvandelay
That's fine, I have access to a Windows PC
