I have checked the disc multiple times and there are no visible scratches or smudges but I keep getting the following errors. I have trimmed it down due to all of the repeats. I have cleaned the disc a few times and it always seems to fail around the same area. Any idea?
The source file '/BDMV/STREAM/00004.m2ts' is corrupt or invalid at offset 23255070720, attempting to work around
Repeats a bunch of times
The source file '/BDMV/STREAM/00004.m2ts' is corrupt or invalid at offset 23255076864, attempting to work around
The source file '/BDMV/STREAM/00004.m2ts' is corrupt or invalid at offset 23255083008, attempting to work around
The source file '/BDMV/STREAM/00004.m2ts' is corrupt or invalid at offset 23255089152, attempting to work around
The source file '/BDMV/STREAM/00004.m2ts' is corrupt or invalid at offset 23255095296, attempting to work around
The source file '/BDMV/STREAM/00004.m2ts' is corrupt or invalid at offset 23255101440, attempting to work around
The source file '/BDMV/STREAM/00004.m2ts' is corrupt or invalid at offset 23255107584, attempting to work around
The source file '/BDMV/STREAM/00004.m2ts' is corrupt or invalid at offset 23255113728, attempting to work around
The source file '/BDMV/STREAM/00004.m2ts' is corrupt or invalid at offset 23255119872, attempting to work around
The source file '/BDMV/STREAM/00004.m2ts' is corrupt or invalid at offset 23255052288, attempting to work around
The source file '/BDMV/STREAM/00004.m2ts' is corrupt or invalid at offset 23255058432, attempting to work around
The source file '/BDMV/STREAM/00004.m2ts' is corrupt or invalid at offset 23255064576, attempting to work around
ETC ETC ETC
Fist of Legend errors
Re: Fist of Legend errors
I think there is something wrong with this disc. I couldn't even copy that file straight over so I think it's just a bad disc.
Hi!
Exchange it at the original place of purchase for a new replacement...
Yup already in the works. Just wanted to verify it was the disc first
