AACSv82 Dump Submission - LABX-8890~3
ijnkongo25
Post by ijnkongo25 »
Attached the dump files for the 4 discs. Already emailed svq@makemkv.com.
Thanks in advance for decryption.
MKB_v82_2ND_LIVE_TOUR.zip
(440.03 KiB) Downloaded 1253 times
Edit: Solved, thank you!
TheM14
Re: AACSv82 Dump Submission - LABX-8890~3
Post by TheM14 »
try latest keydb.cfg from http://fvonline-db.bplaced.net/
put keydb into the same folder as the files you dumped
