Sure email me that info see belowgurivan wrote: Thu Mar 27, 2025 8:38 am Hello, I've just bought BDR-XS07S. Please help me to flash it to UHD
Manufacturer: PIONEER
Product: BD-RW BDR-XS07
Revision: 1.01
Serial number:
Firmware date: 2020-09-03
Bus encryption flags: 13
Drive platform: RS8E20
Firmware version: 1.01
BDR-XS07S UHD Flash
Re: BDR-XS07S UHD Flash
playback9063
Is it possible to get this working with UHD? Thanks!
OS device name: E:
Product: BD-RW BDR-XD07
Revision: 1.03
Serial number: ...
Firmware date: 2020-08-20
Drive platform: RS8D30
Firmware version: 1.03
yes see contact info belowplayback9063 wrote: Thu Mar 27, 2025 8:37 pm Is it possible to get this working with UHD? Thanks!
OS device name: E:
Revision: 1.03
Serial number: ...
moisty
Could I get a PM on this one? Y'all are saints making sure there's always going to be libraries of media to fall back on in the future
Revision: 1.01
Serial number:
Revision: 1.01
Serial number:
Sure email me for the flashermoisty wrote: Sat Apr 19, 2025 1:12 pm Could I get a PM on this one? Y'all are saints making sure there's always going to be libraries of media to fall back on in the future
Revision: 1.01
Serial number:
moisty
The auto flasher worked perfectly! Thank you!Billycar11 wrote: Sat Apr 19, 2025 9:15 pmSure email me for the flashermoisty wrote: Sat Apr 19, 2025 1:12 pm Could I get a PM on this one? Y'all are saints making sure there's always going to be libraries of media to fall back on in the future
Revision: 1.01
Serial number:
auburnmk
I also have this drive with 1.03 firmware on macOS. A little help? Thanks!
ngkrich
Hi Coopervid
Thank you for all the help.
Would you be able to help unlock my drive for UHD.
Here is the info
Thanks,
OS device name: E:
Product: BD-RW BDR-XS07U
Revision: 1.03
Serial number: ...
Firmware date: 2023-01-06
Highest AACS version: 68
Firmware version: ID05
Here is the info
Thanks,
OS device name: E:
Revision: 1.03
Serial number: ...
Your firmware is too new. You have to wait until Mike has cracked the encrypted firmwares.ngkrich wrote: Wed May 14, 2025 2:11 am Hi Coopervid
Here is the info
Thanks,
OS device name: E:
Revision: 1.03
Serial number: ...
ngkrich
Ahh, okay thank you!Coopervid wrote: Wed May 14, 2025 2:47 amYour firmware is too new. You have to wait until Mike has cracked the encrypted firmwares.ngkrich wrote: Wed May 14, 2025 2:11 am Hi Coopervid
Here is the info
Thanks,
OS device name: E:
Revision: 1.03
Serial number: ...
Soulpepper
Hey There, I'm looking to flash / cross flash my Pioneer to be able to run 4k UHD. Is that possible and what do I need to do?
Pioneer BDR-XS07S
REV 1.01
Driver Version: 10.0.22621.5262
06/20/06
Pioneer BDR-XS07S
REV 1.01
06/20/06
Please post the complete Makemkv info with the Libredrive section as well.Soulpepper wrote: Thu May 15, 2025 9:19 pm Hey There, I'm looking to flash / cross flash my Pioneer to be able to run 4k UHD. Is that possible and what do I need to do?
Pioneer BDR-XS07S
REV 1.01
06/20/06
espinoza
Hi All,
I've got this drive:
Could anyone help me out with info on if / how this is patchable for UHD?
Many thanks
Revision: 1.00
Serial number:
Firmware date: 2019-01-07
Highest AACS version: 64
Firmware version: 1.00
Many thanks
willie3204
Hello, it looks like my drive is enabled for libredrive though its not loading the discs. Do I need to flash it?
OS device name: /dev/sr0
Product: BD-RW BDR-XS06
Revision: 1.01
Serial number: ...
Firmware date: 2015-03-24
Drive platform: RS8721
Firmware name: PIONEER BDR-XS06
No disc inserted-
PM sent.espinoza wrote: Sat May 31, 2025 5:38 pm Hi All,
Drive Information Manufacturer: PIONEER Product: BD-RW BDR-XS07 Revision: 1.00 Serial number: Firmware date: 2019-01-07 Bus encryption flags: 13 Highest AACS version: 64 LibreDrive Information Status: Enabled Drive platform: RS8E20 Firmware name: PIONEER BDR-BDS7 Firmware type: Original (unpatched) Firmware version: 1.00 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes
Many thanks![]()
