Improving vocals from Blu-rays?
Bsmooth
Post by Bsmooth »
Just started getting my blurays discs on a hardrive using MKV and Handbrake. I'm a bit on in years and I guess my hearing isn't what it used to be. I'm finding it a bit difficult hearing vocals from movies after I get the files onto my HD. I'm watching on a pretty old Samsung, but no night settings to play with.
In your experience is there a way to improve settings in Handbrake to improve the vocals a bit? I read you can set the audio Dynamic compression between 1 and 2.5, but not sure where might be the best place.
Its strange If I watch the same movie being broadcast the vocals seem fine, but from a bluray rip they are very quiet.
Also do the audio settings like mixing from say an AC3 to AAC make a difference in vocals as well, lots of options here. Right now I mix them down to stereo, but maybe lose vocals in the process somewhere?.
I also have subtitles on and usually have a few choices including SRT files as well.
Any help would be greatly appreciated.
jinx100
Re: Improving vocals from Blu-rays?
Post by jinx100 »
The vocals are difficult to discern on some films. I think it is just bad sound engineering on some newer films. My Handbrake process is like yours, reducing the 5.1 channel to AAC stereo. Maybe someone with a theater sound system will comment if that helps the vocals.
My profile for blu-ray discs does add 6 db gain to the audio but no dynamic compression. The dynamic compression just seems to raise the background noise in the quieter audio sections of the film.
Bsmooth
Post by Bsmooth »
I was hoping the Dynamic Compression would help. Its frustrating, finally getting the nice clear video and the Audio not keeping up.
Bsmooth
Post by Bsmooth »
Thats a great article, reminds me a bit about the Loudness wars we had a few years ago with music CD's and how it was mixed. I love it, technology jumps ahead leaps and bounds, and we get dialogue we can't understand. A lot of it sound like just plain laziness. Don't they get it? Its a package deal, sound and video. A lot of us have these great killer Home Theater setups, and by the time we get the actual movie, it all falls apart.
Thing is though If one can get it right, they all can. Its going to get to the point we'll have to listen to it in Mono, wouldn't that be sad.
So If cutting back on DR won't help, what will?
jinx100
Post by jinx100 »
Check what audio adjustments are on your TV. Anything to reduce the bass should make the dialog more prominent.
In my view, the best improvement one can make is to use a dedicated speaker setup as opposed to whatever speakers come in the TV. Most experiences I've had with speakers built into a TV have been terrible.
Bsmooth
Post by Bsmooth »
Is there a away to run it thru Audacity somehow, without it taking 2 hours? Or maybe seperate the vocals and then run it thru Audacity?
There are plugins that can isolate vocals/dialog from a track. I haven't used them, so I can only speculate. For example:
https://plugins.audacityteam.org/ai-plugins/ai-plugins
https://www.izotope.com/en/products/rx/features/dialogue-isolate.html
You could use MKVToolNix to move an audio track from a .mkv file into its own separate file, process it in Audacity or whatever to boost the vocals, then use MKVToolNix to put the updated audio back into the .mkv file.
Some playback systems like JRiver Media Center allow for using various plugins during playback. I don't know if they have some kind of vocal boost plugin that could be used in real time. I'm a Plex user, so all I know about JRiver MC is what I read on the internet. :)
Bsmooth
Post by Bsmooth »
I keep forgetting how versatile MKVToolNix is. Yes your quite right , I could use it to do that, although I must admit, its not something I've done before. Give me something to fool around with.
safariff
Post by safariff »
https://gist.github.com/seamonkey420/a3 ... b22def7b5a
This script has served me well in the past.
