Cant backup TailSpin/Disney dvds
tigerike
Post by tigerike » Mon Apr 21, 2025 6:11 pm
I have tried multiple disks and have gotten the same issue on all (same with other Disney disks too).
My drive is in a USB enclosure but I havent had any issues with other disks, especially after flashing the libredrive firmware.
I compiled the linux client with a fresh compile of the latest ffmeg to see if that would fix my issues but it hasnt.
I also tried running as root, as suggested in some other threads, but as I expected this didint resolve anything.
Any thoughts?
---- Drive info and run log ----
OS device name: /dev/sr0
Current profile: DVD-ROM
Product: BD-RE WH14NS40
Revision: 1.05
Serial number: ...
Highest AACS version: 76
Firmware version: 1.05
Disc Information
Label: TA2-0N-NT1.2_DES
Timestamp: 2007-09-11 17:18:53
Protection: CSS/CPPM
Data capacity: 6.53 Gb
Disc type: DVD-ROM
Disc size: 120mm
Maximum read rate: 10.08 Mbps [1x]
Number of layers: 2 (PTP)
Log:
MakeMKV v1.18.1 linux(x64-release) started
Error 'Scsi error - ILLEGAL REQUEST:READ OF SCRAMBLED SECTOR WITHOUT AUTHENTICATION' occurred while reading 'BD-RE HL-DT-ST BD-RE WH14NS40 1.05 KL9O6RI5759' at offset '1048576'
Backing up disc into folder "/mnt/extra/disks/dvds/backup/TA2-0N-NT1.2_DES.iso"
Region setting of drive HL-DT-ST:BD-RE WH14NS40 does not match the region of currently inserted disc, trying to work around...
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading 'BD-RE HL-DT-ST BD-RE WH14NS40 1.05 KL9O6RI5759' at offset '1390282752'
Backup failed
hoth80
Re: Cant backup TailSpin/Disney dvds
Post by hoth80 » Tue Apr 22, 2025 12:05 pm
Drive region not set?
Set drive region 1
Disney lot structure protection discs.
LG drive many problem reading.
Pioneer better reading. Not perfect, retry.
Post by dcoke22 » Tue Apr 22, 2025 1:08 pm
The Ultimate UHD Drives Flashing Guide recommends flashing a WH14NS40 on any Firmware directly to > WH16NS60 1.02MK.
tigerike
Post by tigerike » Tue Apr 22, 2025 10:37 pm
I have tried multiple times with multiple disks.
I must have misread the UHD flashing guide because I though I had to use the WH14NS40 firmware for this drive, I will update to WH16NS60 1.02MK and report back if it fixes the issue.
tigerike
Post by tigerike » Tue Apr 22, 2025 11:16 pm
ok, flashing to WH16NS60 1.02MK did the trick, thanks!
