#10831 Post by RESET_9999 » Mon Mar 31, 2025 10:31 pm
yes, you have to disable smooth gradation. This setting removes fine details anyway.
HDR10:
DoVi
daffie
#10832 Post by daffie » Tue Apr 01, 2025 5:53 am
Will try it again with smooth gradation off when I'm back from work later tonight.
LG OLED65G1RLA / Samsung HW-Q990D / Panasonic UB820 / Ugoos AM6B+ (CE with avdvplus Build)
rosavanwinkle
#10833 Post by rosavanwinkle » Tue Apr 01, 2025 4:24 pm
My god....i havent being on this page in a while....the scripter who made this first happen rocking hard i see....
im gonna need a update on whats being changed dam....
Mediaplayer: Nvidia Shield TV Pro
TV: LG 55SK7900PLA
Soundbar: LG SK8 (not LG SK8Y)
plex pass user
Discord:Rosa#1111
daffie
#10834 Post by daffie » Tue Apr 01, 2025 9:07 pm
RESET_9999 wrote: Mon Mar 31, 2025 10:31 pm yes, you have to disable smooth gradation. This setting removes fine details anyway.
HDR10:
DoVi
Did the comparison again with smooth gradation off but it doesn't change anything. I hardly see any difference between the HDR10 sample files and the Dovi ones.
#10835 Post by RESET_9999 » Tue Apr 01, 2025 9:53 pm
daffie wrote: Tue Apr 01, 2025 9:07 pm Did the comparison again with smooth gradation off but it doesn't change anything. I hardly see any difference between the HDR10 sample files and the Dovi ones.
Are you watching in a dark room?
Near black Posterization and banding on LG OLED TVs is a well-known issue, and many people have moved to QD-OLED Samsung because of that. My Samsung monitor and Hisense LED TV don't have any of those LG issues.
daffie
#10836 Post by daffie » Wed Apr 02, 2025 6:22 am
RESET_9999 wrote: Tue Apr 01, 2025 9:53 pm
Yes I'm watching in a dark room. The sun was down for hours and there were no lights.
Guess I still got a good one from LG :)
I would never move to Samsung by the way. A company that doesn't support Dolby Vision can't take my money.
#10837 Post by RESET_9999 » Wed Apr 02, 2025 10:34 am
except there is no exception to this lg issues, even the latest G5 has it..
you just don't see the problem
daffie
#10838 Post by daffie » Wed Apr 02, 2025 11:27 am
Glad I don't see the problem :D
deadchip12
#10839 Post by deadchip12 » Thu Apr 10, 2025 3:14 am
@RESET_9999
For Nosferatu (2024), if my cmv 2.9 bluray version is extended cut and your cmv 4.0 RPU is theatrical then they won't work together, right?
coopzr
#10840 Post by coopzr » Thu Apr 10, 2025 4:13 am
deadchip12 wrote: Thu Apr 10, 2025 3:14 am @RESET_9999
I'm not reset, but that's correct. It will work up until the first extra/added scene, and then everything will be out of sync thereafter.
daffie
#10841 Post by daffie » Tue Apr 22, 2025 7:57 am
RESET_9999 wrote: Wed Apr 02, 2025 10:34 am except there is no exception to this lg issues, even the latest G5 has it..
I actually didn't see the problem because the problem was not there for me at that time :-)
I had my TV calibrated yesterday and now in the calibrated picture I can clearly see the banding in ''The Martian'' sample in HDR10.
BUT this goes away for 90% by setting smooth gradation to LOW.
In Dolby Vision there is no banding - also with smooth gradation OFF.
#10842 Post by RESET_9999 » Tue Apr 22, 2025 10:52 am
Yeah, I'm hearing the same from the G5. It's a good thing we can generate DV for everything.
LV8HD
#10843 Post by LV8HD » Wed Apr 23, 2025 1:33 pm
In the HDR10+ injection workflow the delay doesn't get applied.
Here are the original scene cuts:
"SceneInfoSummary": {
    "SceneFirstFrameIndex": [
      0,
      24,
      144,
      180,
      300,
      336,
      456,
      492,
      612,
      4213,
      4232,
      4514,
      4561,
      4669,
      4884,
      5120,
And here are the "synced" scene cuts:
      0,
      24,
      144,
      180,
      300,
      336,
      456,
      492,
      612,
      4213,
      4232,
      4514,
      4561,
      4669,
      4884,
      5120,
May it be a problem in the script that delays HDR10+ metadata?
#10844 Post by RESET_9999 » Wed Apr 23, 2025 2:24 pm
I dont know, works fine for me when I check the new scene cuts in 2-1 and I get the framecount mismatch at injection..
Duplicating frame one, 24 times...
Warning: mismatched lengths. video 2876, HDR10+ JSON 2900
You have to check the injected/extracted json . This was the method used before hdr10plus_tool added native resync support. Hdr10plus tool recalculates the scene at injection.
If you get the latest beta and update hdr10plus_tool, you should be able to check sync directly with the edited json.
deadchip12
#10845 Post by deadchip12 » Wed Apr 23, 2025 4:39 pm
RESET_9999 wrote: Tue Apr 22, 2025 10:52 am Yeah, I'm hearing the same from the G5. It's a good thing we can generate DV for everything.
Not pc gaming though.
