HotJuicyBurgers
Hey all, been trying to flash my drive in linux, but my drive name is different than everyone elses. Anyone know what is up?
[root@8c4041fefc7c bin]# ./makemkvcon f -l
Found 1 drives(s)
00: dev_21:2, /dev/sr0, /dev/sr0
HL-DT-ST_BD-RE__WH14NS40_1.05_212005061444_KX1OC9E4345
Found 1 drives(s)
sjaeger172004
Hi
I am new to flashing and to the site.
I am in Australia and looking for an external 4K drive.
How hard and risky to flash? And which drive to get thanks
See my signature.sjaeger172004 wrote: Sat Apr 26, 2025 10:12 pm Hi
angelus2141
HI All,
First time here. So im new to ripping Blu-ray but looking to get into it and have a couple of questions. From posts ive read UHD and Blu-ray dont seem to be the same thing are they different? I was always under the impression they were the same.
Second I looked at the list of drive and when searching online I find drives with slightly different naming conventions. For example Pioneer BDR-S13E-X vs Pioneer BDR-S13J-X, is there a significance to the different drive lettering? Will ripping still work on the J vs the E?
TIA
TIA
disneyvader
I looking to buy one of the drives from the list of confirmed to work list but all of the product codes seem to be american product codes or at least only american sites show up in my searches
any idea of what the european product codes are or possibly EU sites where i can buy a drive?
Doesn't matter at all if you get a drive with firmware starting 12-2022. Those are all screwed. Older ones can be crossflashed.angelus2141 wrote: Sun Apr 27, 2025 4:34 am HI All,
TIA
sjaeger172004
Found an old Pioneer BD-RW BDR-XD07 I had lying around
Does this need flashing?
OS device name: E:
Manufacturer: PIONEER
Product: BD-RW BDR-XD07
Revision: 1.03
Serial number: AFDL010327WL
Firmware date: 2020-08-20
Bus encryption flags: 13
Drive platform: RS8D30
Firmware version: 1.03
And my new Verbatiam
OS device name: F:
Product: BD-RE BU40N
Revision: 1.05
Serial number: MO2OB193245
OS device name: E:
Revision: 1.03
OS device name: F:
Revision: 1.05
sure both can be flashed the lg you can do on your own the pioneer email me about itsjaeger172004 wrote: Mon Apr 28, 2025 3:11 am Found an old Pioneer BD-RW BDR-XD07 I had lying around
OS device name: E:
Revision: 1.03
OS device name: F:
Revision: 1.05
but if you want me or marty can do the lg too
From what I’ve understood, Angelus?angelus2141 wrote: Sun Apr 27, 2025 4:34 am HI All,
TIA
UHD and blu-ray are two different types of bluray.
‘Bluray’ content is usually in the 1920*1080 resolution.
‘UHD’ content is on a higher capacity bluray: and in 3840*2160 resolution.
I’m very aware people will be correcting me!
You are correct...Cuddy2977 wrote: Wed Apr 30, 2025 7:24 amFrom what I’ve understood, Angelus?angelus2141 wrote: Sun Apr 27, 2025 4:34 am HI All,
TIA
Adding to that, UHD content is encoded using the newer HEVC/H.265 whereas standard blu-ray is encoded using H.264.
HK_Rickyeva
so i bouught the pioneer drive , can it be flash???
Product: BD-RW BDR-S12JX
Revision: 1.01
Serial number: ...
Firmware date: 2020-07-21
Highest AACS version: 76
Drive platform: RS8F01
Firmware version: 1.01/ID72
Revision: 1.01
Serial number: ...
disneyvader
Would these drives work after flashing? They don't appear in the list of proven drives but I am unable to find any of those here in the EU
LG BH16NS40
Hitachi-LG Data Storage BH16NS55
LG BH16NS40
doodoofart
hi @ all and thanks for this great project.
a friend gave me an old external LG BP55EB40 he did not have any use for any longer. It doesn't read UHD discs so he bought another device.
I checked the specs and just wanted to make sure i don't screw it up.
i made a backup with SDFtool Flasher.
I unscrewed the external usb case and the drive itself says: MODEL: BU20N
i would flash "HL-DT-ST-BD-RE_BP55EB40-NB50-1.03-NM00800-212005070924.bin" from this thread viewtopic.php?f=19&t=19113
using this command
is this correct or unnecessary risk?
much appreciated and have a good day
Product: BD-RE BP55EB40
Revision: 1.00
Serial number: MD[CENSORED]
Firmware date: 2115-04-22 15:34
Highest AACS version: 72
Firmware version: 1.00
using this command
.\makemkvcon64.exe f --all-yes -d D: rawflash -i C:\Users\flashgordon\Downloads\HL-DT-ST-BD-RE_BP55EB40-NB50-1.03-NM00800-212005070924.binmuch appreciated and have a good day
No do not flash that drive it will brickdoodoofart wrote: Thu May 01, 2025 9:54 am hi @ all and thanks for this great project.
I unscrewed the external usb case and the drive itself says: MODEL: BU20NCode: Select all
Drive Information OS device name: D: Manufacturer: HL-DT-ST Product: BD-RE BP55EB40 Revision: 1.00 Serial number: MD[CENSORED] Firmware date: 2115-04-22 15:34 Bus encryption flags: 17 Highest AACS version: 72 LibreDrive Information Status: Enabled Drive platform: MT1959 Firmware type: Original (unpatched) Firmware version: 1.00 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes
using this commandis this correct or unnecessary risk?Code: Select all
BH16NS55 is in the list.disneyvader wrote: Thu May 01, 2025 9:18 am Would these drives work after flashing? They don't appear in the list of proven drives but I am unable to find any of those here in the EU
LG BH16NS40
WH16NS40 is in the list. (WH/BH drives are the same thing)
