Ultimate UHD Drives Flashing Guide Updated 2025
dramaticaudio
Post by dramaticaudio »
Thanks for the reply!
Yeah, you were absolutely right. Duh. :)
It went through the process and said it was 100% done but when I open MakeMKV, it still registers the 1.05 firmware. Maybe it's encrypted?
dramaticaudio
Yeah, it was encrypted. Worked with the other command. And done! :)
Thanks again for the help!
HotJuicyBurgers
Post by HotJuicyBurgers »
Hey all, been trying to flash my drive in linux, but my drive name is different than everyone elses. Anyone know what is up?
[root@8c4041fefc7c bin]# ./makemkvcon f -l
Found 1 drives(s)
00: dev_21:2, /dev/sr0, /dev/sr0
HL-DT-ST_BD-RE__WH14NS40_1.05_212005061444_KX1OC9E4345
sjaeger172004
Post by sjaeger172004 »
Hi
I am new to flashing and to the site.
I am in Australia and looking for an external 4K drive.
How hard and risky to flash? And which drive to get thanks
sjaeger172004 wrote:
Sat Apr 26, 2025 10:12 pm
Hi
See my signature.
angelus2141
Post by angelus2141 »
HI All,
First time here. So im new to ripping Blu-ray but looking to get into it and have a couple of questions. From posts ive read UHD and Blu-ray dont seem to be the same thing are they different? I was always under the impression they were the same.
Second I looked at the list of drive and when searching online I find drives with slightly different naming conventions. For example Pioneer BDR-S13E-X vs Pioneer BDR-S13J-X, is there a significance to the different drive lettering? Will ripping still work on the J vs the E?
TIA
disneyvader
Post by disneyvader »
I looking to buy one of the drives from the list of confirmed to work list but all of the product codes seem to be american product codes or at least only american sites show up in my searches
any idea of what the european product codes are or possibly EU sites where i can buy a drive?
angelus2141 wrote:
Sun Apr 27, 2025 4:34 am
HI All,
TIA
Doesn't matter at all if you get a drive with firmware starting 12-2022. Those are all screwed. Older ones can be crossflashed.
sjaeger172004
Found an old Pioneer BD-RW BDR-XD07 I had lying around
Does this need flashing?
OS device name: E:
Manufacturer: PIONEER
Product: BD-RW BDR-XD07
Revision: 1.03
Serial number: AFDL010327WL
Firmware date: 2020-08-20
Bus encryption flags: 13
Drive platform: RS8D30
Firmware version: 1.03
And my new Verbatiam
OS device name: F:
Product: BD-RE BU40N
Revision: 1.05
Serial number: MO2OB193245
Mon Apr 28, 2025 3:11 am
OS device name: E:
Revision: 1.03
OS device name: F:
Revision: 1.05
sure both can be flashed the lg you can do on your own the pioneer email me about it
but if you want me or marty can do the lg too
Cuddy2977
Post by Cuddy2977 »
HI All,
TIA
From what I’ve understood, Angelus?
UHD and blu-ray are two different types of bluray.
‘Bluray’ content is usually in the 1920*1080 resolution.
‘UHD’ content is on a higher capacity bluray: and in 3840*2160 resolution.
I’m very aware people will be correcting me!
Cuddy2977 wrote:
Wed Apr 30, 2025 7:24 am
HI All,
TIA
You are correct...
Adding to that, UHD content is encoded using the newer HEVC/H.265 whereas standard blu-ray is encoded using H.264.
HK_Rickyeva
Post by HK_Rickyeva »
so i bouught the pioneer drive , can it be flash???Image
Product: BD-RW BDR-S12JX
Revision: 1.01
Serial number: ...
Firmware date: 2020-07-21
Highest AACS version: 76
Drive platform: RS8F01
Firmware version: 1.01/ID72
disneyvader
Would these drives work after flashing? They don't appear in the list of proven drives but I am unable to find any of those here in the EU
LG BH16NS40
Hitachi-LG Data Storage BH16NS55
doodoofart
Post by doodoofart »
hi @ all and thanks for this great project.
a friend gave me an old external LG BP55EB40 he did not have any use for any longer. It doesn't read UHD discs so he bought another device.
I checked the specs and just wanted to make sure i don't screw it up.
i made a backup with SDFtool Flasher.
Product: BD-RE BP55EB40
Revision: 1.00
Serial number: MD[CENSORED]
Firmware date: 2115-04-22 15:34
Highest AACS version: 72
Firmware version: 1.00
I unscrewed the external usb case and the drive itself says: MODEL: BU20N
i would flash "HL-DT-ST-BD-RE_BP55EB40-NB50-1.03-NM00800-212005070924.bin" from this thread viewtopic.php?f=19&t=19113
using this command
.\makemkvcon64.exe f --all-yes -d D: rawflash -i C:\Users\flashgordon\Downloads\HL-DT-ST-BD-RE_BP55EB40-NB50-1.03-NM00800-212005070924.bin
is this correct or unnecessary risk?
much appreciated and have a good day
