BDR 212V UHD Guide
Re: BDR 212V UHD Guide
Rudyard wrote: Sun Apr 20, 2025 11:01 pm Got another BDR-212DBK. MakeMKV shows the exact same info now as it showed with the previous unit, same firmware etc, so I just flashed the same files I already had, since they had been successfully flashed on the first unit. And this time, according to the flashing program, everything went OK too. But the unit won't read any BD disc, neither regular not UHD discs. It reads DVD, though.
I've flashed it again just in case, but to no avail. Maybe this is a faulty unit. I should have checked if it read BD discs before flashing, like I did with the previous unit... I'll probably need to return it. Is there any way I can flash the original firmware back?
Product: BD-RW BDR-212D
Revision: 1.02
Firmware date: 2022-03-16
Thanks in advance.
PM sent.
Rudyard
Post by Rudyard »
Thank you! Next time I'll be more cautious
jtuts
Post by jtuts »
I should be getting this drive tomorrow and just wanted to get some clarification. From what I can tell, we are not able to flash this particular drive ourselves and the instructions are only available through PM. Is this correct?
If not, can someone please point me to the correct files/instructions? I would like to start understanding the process in preparation for flashing the drive.
jtuts wrote: Fri May 02, 2025 12:02 am Hello,
Post your Makemkv info when you receive it. Please try CDs, DVDs and BDs when it arrives. Sometimes people receive defective returned drives.
jtuts
Post by jtuts »
Coopervid wrote: Fri May 02, 2025 9:02 am
Okay, will do. Thanks again!
jtuts
Post by jtuts »
@Coopervid
Okay, finally got this setup, here is info you requested:
BR - good
CD - good
DVD - good
UHD - no disc inserted (which I assume is expected)
Screenshot 2025-05-02 174620.png (11.53 KiB) Viewed 17382 times
Edit: I also am using the Vantec NexStar DX2 enclosure, if that matters at all.
jtuts wrote: Sat May 03, 2025 12:50 am @Coopervid
BR - good
CD - good
DVD - good
PM sent. Important when using an enclosure for flashing. Remove BOTH power and USB afterwards.
valentine
Post by valentine »
Hey Coopervid, could I perhaps get some help cross-flashing my BDR-212DBK? Here is the makemkv info:
OS device name: /dev/rdisk4
Manufacturer: PIONEER
Revision: 1.02
Serial number:
Bus encryption flags: 13
Highest AACS version: 68
Drive platform: RS8F00
Firmware version: 1.02/ID61
valentine wrote: Mon May 05, 2025 10:01 pm Hey Coopervid, could I perhaps get some help cross-flashing my BDR-212DBK? Here is the makemkv info:
Revision: 1.02
Serial number:
PM sent.
Wolf2142
Post by Wolf2142 »
Hey, sorry been a long time since I used any forums and tried to post a topic (pending?), but maybe this is also a correct place?
I have the below drive, and from reading the forums I need to flash it to use it for UHD, can anyone help me out with the process via PM? I have never flashed a drive before and don't want use the wrong firmware or tool et al. and end up bricking the thing. Thank you in advance!
OS device name: XXXXX
Revision: 1.02
Serial number: XXXXXXXXXXX
Highest AACS version: 81
Wolf2142 wrote: Tue May 06, 2025 9:28 pm Hey, sorry been a long time since I used any forums and tried to post a topic (pending?), but maybe this is also a correct place?
Revision: 1.02
PM sent.
briank
Post by briank »
Hi, could I please get the instructions for flashing this drive? Thank you!
OS device name: XX
Revision: 1.00
Serial number: XXXXXXXXXXXX
Firmware date: 2019-01-10
Highest AACS version: 77
Firmware version: 1.00/ID61
geraldog
Post by geraldog »
OS device name: /dev/sr0
Revision: 1.00
Serial number: ...
Hi Coopervid, could I get instructions and the firmware file for crossflashing the above 212dbk?
hud55duh
Post by hud55duh »
Greetings been using MKV years and finally purchased my first UHD and yes didn't work. :) Would be great to get instruction on how to flash this drive. Is this windows only solution. Thank you in advance.
Drive information:
Product: BD-RW BDR-212V
Revision: 1.00
Firmware date: 2020-08-07
Firmware version: 1.00/ID06
AbyssalReClass
Post by AbyssalReClass »
Hello all, I've got a Pioneer BDR-212DBK that I picked up off of Amazon recently. It works great, except that it won't rip UHD out of the box. Is it possible to flash this from a Linux PC?
Here is my MakeMKV info:
Current profile: DVD-ROM
Revision: 1.02
Highest AACS version: 65
