97Hugo
#2881 Post by 97Hugo » Tue Apr 15, 2025 5:33 pm
Billycar11 wrote: Mon Apr 14, 2025 6:27 pm
97Hugo wrote: Mon Apr 14, 2025 12:16 pm Hello, I was searching for information about my drive to see whether it can support 4k blu ray, but I ended up with no results. May I ask if "Buffalo BRXL-PTV6U3 SVB" is compatible in any way or form? Thanks!
Here's the information on MakeMKV
OS device name: G:
Manufacturer: BUFFALO
Product: Optical Drive
Revision: BN14
Serial number: HelloWorld
Firmware date: 2121-06-21 13:33
Bus encryption flags: 1F
Highest AACS version: 81
Treat it as a bu40n
Thank you, I will try it out and see if it works!
dylan323i
#2882 Post by dylan323i » Wed Apr 16, 2025 6:04 pm
Hey so I just but a new sealed in box Pioneer BDR-209dbk with a MFG date of 2014 will post the drive details when it arrives kinda curious though what software gets flashed to these. I noticed with the LG’s they all generally use the same file same for pioneers? Is this drive basically a scaled down 212 or are there legitimate hardware differences?
#2883 Post by Billycar11 » Wed Apr 16, 2025 9:10 pm
dylan323i wrote: Wed Apr 16, 2025 6:04 pm Hey so I just but a new sealed in box Pioneer BDR-209dbk with a MFG date of 2014 will post the drive details when it arrives kinda curious though what software gets flashed to these. I noticed with the LG’s they all generally use the same file same for pioneers? Is this drive basically a scaled down 212 or are there legitimate hardware differences?
Email me your makemkv drive info section
Flasher and fw are completely different
dylan323i
#2884 Post by dylan323i » Sat Apr 19, 2025 10:40 pm
Billycar11 wrote: Wed Apr 16, 2025 9:10 pm
Email sent
HotJuicyBurgers
#2885 Post by HotJuicyBurgers » Sun Apr 20, 2025 2:47 am
Hey!
Is there anyone that has written a guide or a youtube video on how to flash a drive attached to an unraid server? I have MakeMKV installed in a docker container. I'll post my drive info below, new to all this so any help would be appreciated. I'm assuming the gui doesn't work for me as well like it does on windows.
OS device name: /dev/sr0
Product: BD-RE WH14NS40
Revision: 1.05
Serial number:
Harware support: Yes
Firmware support: No
Firmware version 1.05
#2886 Post by Billycar11 » Sun Apr 20, 2025 2:01 pm
HotJuicyBurgers wrote: Sun Apr 20, 2025 2:47 am Hey!
Revision: 1.05
Serial number:
linux commands are in first post
Duramax6.6l
#2887 Post by Duramax6.6l » Sun Apr 20, 2025 7:21 pm
I am looking at this drive and I am wondering if it is compatible..
https://www.amazon.com/PIONEER-Internal ... ref=sr_1_2
or is there a better drive to get
#2888 Post by Billycar11 » Sun Apr 20, 2025 10:08 pm
Duramax6.6l wrote: Sun Apr 20, 2025 7:21 pm Hello,
Likely not needs fw before 12/22
Duramax6.6l
#2889 Post by Duramax6.6l » Sun Apr 20, 2025 10:32 pm
What is a good drive to get then..
#2890 Post by Billycar11 » Mon Apr 21, 2025 4:48 am
Duramax6.6l wrote: Sun Apr 20, 2025 10:32 pm What is a good drive to get then..
well they are getting very hard to come by i have some pioneers left if your in the usa asmcom and marty t0o for EU area and AU area
dramaticaudio
#2891 Post by dramaticaudio » Mon Apr 21, 2025 5:10 am
I need a little help if someone would be so kind.
Trying to flash a new BU40N (LG) from 1.05 to 1.03, using Terminal on MacOS. I'm getting a Drive Not Found error. It definitely sees it in the cmd just before. Would someone please take a look and see if perhaps I'm doing something wrong? TIA!
-jscott
Terminal log:
DAP-M4TICUS:tmp jscott$ cp ~/jscott/tmp/HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin /tmp
DAP-M4TICUS:tmp jscott$ ls
sdf.bin
DAP-M4TICUS:tmp jscott$ cd /Applications/MakeMKV.app/Contents/MacOS
DAP-M4TICUS:MacOS jscott$ ./makemkvcon f -l
Found 1 drives(s)
00: /IOBDServices/D81BBE52
HL-DT-ST_BD-RE_BU40N_1.05_212404231347_MOAOAM90007
DAP-M4TICUS:MacOS jscott$ ./makemkvcon f -d '/IOBDServices/D5D25996' -f /tmp/sdf.bin rawflash main -i /tmp/HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin
Drive "/IOBDServices/D5D25996" not found
#2892 Post by Billycar11 » Mon Apr 21, 2025 5:20 am
dramaticaudio wrote: Mon Apr 21, 2025 5:10 am I need a little help if someone would be so kind.
-jscott
Terminal log:
sdf.bin
Found 1 drives(s)
shouldn't it be this ... /IOBDServices/D81BBE52 for you drive
#2893 Post by dcoke22 » Mon Apr 21, 2025 5:21 am
-jscott
Terminal log:
sdf.bin
Found 1 drives(s)
According to your log, the name of your optical drive is: /IOBDServices/D81BBE52
The one you specified in your command is not that.
dramaticaudio
#2894 Post by dramaticaudio » Mon Apr 21, 2025 5:46 am
Thanks for the reply!
Yeah, you were absolutely right. Duh. :)
It went through the process and said it was 100% done but when I open MakeMKV, it still registers the 1.05 firmware. Maybe it's encrypted?
dramaticaudio
#2895 Post by dramaticaudio » Mon Apr 21, 2025 5:55 am
Yeah, it was encrypted. Worked with the other command. And done! :)
Thanks again for the help!
