AACS v82 Blu-ray Disc Godzilla Minus One Minus Color Disk
woodworker
Post by woodworker »
I can not rip the Godzilla Minus One Minus Color Disk from the 4 Disk Godzilla Minus One - Deluxe Edition
Here is the AACS Export
MKB_v82_Godzilla_Minus_One_0982.tgz
(106.43 KiB) Downloaded 1247 times
Re: AACS v82 Blu-ray Disc Godzilla Minus One Minus Color Disk
Did you also email this dump to svq@makemkv.com?
Post by SamuriHL »
You can also check the keydb.cfg. Download the latest and extract it to your MakeMKV data directory. Alternatively if you're on windows, you can use my tool to sync the keydb found here:
viewtopic.php?f=12&t=16883&p=166510#p166510
