"HashCheck Error": A bad drive or a bad disk
happyripping2025
Post by happyripping2025 » Thu Mar 13, 2025 5:47 pm
Recently, I'm using makemkv to rip about 80-100 disc. Most of them finish successfully, but couple of them (~10) fail. I'm aware it may have something to do to the dirt on the disc and sometimes cleaning the disc brought the ripping success without any errors.
That said, I'm reading the information on the linked page in the log (http://www.makemkv.com/errors/hashcheck/), and it explicitly says:
Hash check error essentially means that the drive was unable to read the file from the disc, and what more, instead of raising the read error it silently returned corrupted data. Getting this error usually means a failing Blu-ray drive.
So with "hash check failed" errors (on multiple discs), does it suggest the drive may have intermittent failures and is worth a replacement? If I understand the quote message above correctly, the drive may also serve bad data silently when I insert a Windows installation disc or other data disc? That seems very problematic.
Using LibreDrive mode (v06.3 id=...)
Backing up disc into folder "Z:/Video/backup/ALIEN3_WW"
Processing BD+ code, please be patient - this may take up to few minutes
Processing BD+ code using generic SVQ from builtin/generic.svq
BD+ code processed, got 1 FUT(s) for 20 clip(s)
Hash check failed for file 00701.m2ts at offset 77260800, file is corrupt.
Hash check failed for file 00701.m2ts at offset 80996352, file is corrupt.
Hash check failed for file 00701.m2ts at offset 84535296, file is corrupt.
Hash check failed for file 00701.m2ts at offset 85125120, file is corrupt.
Hash check failed for file 00701.m2ts at offset 85911552, file is corrupt.
Too many hash check errors in file 00701.m2ts.
Hash check for /BDMV/STREAM/00701.m2ts : 0.57% corrupt, 99.38% correct, 99.96% checked.
Hash check failed for file 00775.m2ts at offset 1387063296, file is corrupt.
Hash check failed for file 00775.m2ts at offset 1387259904, file is corrupt.
Hash check failed for file 00775.m2ts at offset 1390995456, file is corrupt.
Hash check failed for file 00775.m2ts at offset 1401415680, file is corrupt.
Hash check failed for file 00775.m2ts at offset 1407707136, file is corrupt.
Too many hash check errors in file 00775.m2ts.
Hash check for /BDMV/STREAM/00775.m2ts : 0.06% corrupt, 99.93% correct, 99.99% checked.
Encountered 21 errors of type 'HashCheck Error' - see http://www.makemkv.com/errors/hashcheck/...
Backup done but 2 files failed hash check
Re: "HashCheck Error": A bad drive or a bad disk
Post by dcoke22 » Thu Mar 13, 2025 11:41 pm
happyripping2025 wrote: Thu Mar 13, 2025 5:47 pm So with "hash check failed" errors (on multiple discs), does it suggest the drive may have intermittent failures and is worth a replacement? If I understand the quote message above correctly, the drive may also serve bad data silently when I insert a Windows installation disc or other data disc? That seems very problematic.
LG calls this feature 'Jamless Play':
Jamless Play Smooths Out Playback of Damaged Blu-ray or DVD Discs
The drive is essentially returning garbage data when it can't properly read a disc. I don't recall if that 'feature' can be turned off or not.
It is my understanding that Pioneer drives don't do this.
MakeMKV can detect this because blu-rays and 4K UHDs have something called the Content Hash Table, which is hashes of all the data on the disc. MakeMKV reads the disc, calculates the hash and compares it to the Content Hash Table stored on the disc. If they match, then the data read was correct. If they don't match, MakeMKV tries the read again until it either gets a good read or the retry limit is reached.
In the case of small percentage of discs ending up with hash check errors, it is probably the discs and not the drive. If most discs end up with hash check errors, then it might be the drive (unless all your discs are trashed for some reason).
In my experience, some drives just don't like some discs. Sometimes the same disc in a different drive will produce different results. This is why I have multiple different drives. Almost always I can get a good rip out of one of my drives, especially after gently cleaning the disc.
happyripping2025
Post by happyripping2025 » Fri Mar 14, 2025 11:36 pm
Thanks for the information. That makes sense.
That said, in order to avoid confusion, I recommend updating the explanation at http://www.makemkv.com/errors/hashcheck/ to call out the possibility of some feature like "jamless play". The wording and reasoning there currently sounds very affirmative that hashcheck error should be considered a bad behavior of drive.
Infexshun
Post by Infexshun » Fri Apr 18, 2025 4:56 pm
Something interesting I've noticed. The only UHD I'm having trouble ripping (Getting Hash Check Errors) are both released in the last year, being "Furiosa" and "The Fall Guy." With all my other (all older releases) films working perfectly. What also interesting to note is The Fall Guy comes with a Theatrical release disc AND an Extended Length disc and I get the same errors. I can't help but wonder if there is something more going on here, maybe some new copy protection at work?
For the record I'm on a Verbatim 43888 with BU40N internals, using the supplied 1.03 firmware supplied from this site.
Post by Billycar11 » Sat Apr 19, 2025 9:20 pm
Infexshun wrote: Fri Apr 18, 2025 4:56 pm Something interesting I've noticed. The only UHD I'm having trouble ripping (Getting Hash Check Errors) are both released in the last year, being "Furiosa" and "The Fall Guy." With all my other (all older releases) films working perfectly. What also interesting to note is The Fall Guy comes with a Theatrical release disc AND an Extended Length disc and I get the same errors. I can't help but wonder if there is something more going on here, maybe some new copy protection at work?
No stop the conspiracy stuff nothing going on other than LG doing junky LG things pioneers never get hash errors
Infexshun
Post by Infexshun » Sat Apr 26, 2025 3:13 pm
[/quote]
I actually just logged on now to followup on my last post and report I've discovered the actual source of the problem. My apologies as I definitely was not trying to spread conspiracies.
The problem: Two movies in my collection, Furiosa and The Fall Guy would get Hash errors, despite every other movie working.
The culprit: The cable I was using. Since the supplied cable was only 16 or so inches long (roughly half a meter), I switched to a 60w high supposedly high bandwith 1 meter cable from Ugreen https://www.amazon.com/dp/B0BLYXSTSQ as my desktop ports were too high for the supplied cable. Made sense at the time and worked perfectly on several films before I got to those two. Yesterday I propped the device on a box and tried the original cable and suddenly no issues with those films anymore.
Why did it work on most but not those two?: I have no idea. But maybe someone else here can shed some light on it. Either way. I guess the lesson learned is always use the provided cable.
Post by Billycar11 » Sat Apr 26, 2025 11:26 pm
Infexshun wrote: Sat Apr 26, 2025 3:13 pm No stop the conspiracy stuff nothing going on other than LG doing junky LG things pioneers never get hash errors
[/quote]
again not caused by that usb and sata have error correction built in thats just how inconsistant lg/asus drives are with their jameless play feature sometimes even when it could read the disc by trying again it says ehh i will put out some garbage data instead and it wont work until a reset
Infexshun
Post by Infexshun » Sun Apr 27, 2025 2:48 pm
Billycar11 wrote: Sat Apr 26, 2025 11:26 pm
[/quote]
To clarify. I spent a good week with the alternate cable frequently re-attempting those films, working on others in between. When I swapped to the official cable, the issue goes away, and when I swap back, the same hash errors creeps in. Maybe we got our wires crossed somewhere. Is it possible I'm commenting on the wrong issue? I was trying to go along with the forum guide of looking for a related issue rather than posting my own.
Post by Billycar11 » Mon Apr 28, 2025 3:08 am
Infexshun wrote: Sun Apr 27, 2025 2:48 pm
still going with luck of the draw those lg/asus drives are really inconsistent you will have hash errors again eventually on the good cable
