Sure email me that info see belowgurivan wrote: Thu Mar 27, 2025 8:38 am Hello, I've just bought BDR-XS07S. Please help me to flash it to UHD
Manufacturer: PIONEER
Product: BD-RW BDR-XS07
Revision: 1.01
Serial number:
Firmware date: 2020-09-03
Bus encryption flags: 13
Drive platform: RS8E20
Firmware version: 1.01
BDR-XS07S UHD Flash
Re: BDR-XS07S UHD Flash
playback9063
Is it possible to get this working with UHD? Thanks!
OS device name: E:
Product: BD-RW BDR-XD07
Revision: 1.03
Serial number: ...
Firmware date: 2020-08-20
Drive platform: RS8D30
Firmware version: 1.03
yes see contact info belowplayback9063 wrote: Thu Mar 27, 2025 8:37 pm Is it possible to get this working with UHD? Thanks!
OS device name: E:
Revision: 1.03
Serial number: ...
Could I get a PM on this one? Y'all are saints making sure there's always going to be libraries of media to fall back on in the future
Revision: 1.01
Serial number:
Revision: 1.01
Serial number:
Sure email me for the flashermoisty wrote: Sat Apr 19, 2025 1:12 pm Could I get a PM on this one? Y'all are saints making sure there's always going to be libraries of media to fall back on in the future
Revision: 1.01
Serial number:
The auto flasher worked perfectly! Thank you!Billycar11 wrote: Sat Apr 19, 2025 9:15 pmSure email me for the flashermoisty wrote: Sat Apr 19, 2025 1:12 pm Could I get a PM on this one? Y'all are saints making sure there's always going to be libraries of media to fall back on in the future
Revision: 1.01
Serial number:
I also have this drive with 1.03 firmware on macOS. A little help? Thanks!
Hi Coopervid
Thank you for all the help.
Would you be able to help unlock my drive for UHD.
Here is the info
Thanks,
OS device name: E:
Product: BD-RW BDR-XS07U
Revision: 1.03
Serial number: ...
Firmware date: 2023-01-06
Highest AACS version: 68
Firmware version: ID05
Here is the info
Thanks,
OS device name: E:
Revision: 1.03
Serial number: ...
Your firmware is too new. You have to wait until Mike has cracked the encrypted firmwares.ngkrich wrote: Wed May 14, 2025 2:11 am Hi Coopervid
Here is the info
Thanks,
OS device name: E:
Revision: 1.03
Serial number: ...
Ahh, okay thank you!Coopervid wrote: Wed May 14, 2025 2:47 amYour firmware is too new. You have to wait until Mike has cracked the encrypted firmwares.ngkrich wrote: Wed May 14, 2025 2:11 am Hi Coopervid
Here is the info
Thanks,
OS device name: E:
Revision: 1.03
Serial number: ...
Soulpepper
Hey There, I'm looking to flash / cross flash my Pioneer to be able to run 4k UHD. Is that possible and what do I need to do?
Pioneer BDR-XS07S
REV 1.01
Driver Version: 10.0.22621.5262
06/20/06
Pioneer BDR-XS07S
REV 1.01
06/20/06
Please post the complete Makemkv info with the Libredrive section as well.Soulpepper wrote: Thu May 15, 2025 9:19 pm Hey There, I'm looking to flash / cross flash my Pioneer to be able to run 4k UHD. Is that possible and what do I need to do?
Pioneer BDR-XS07S
REV 1.01
06/20/06
Hi All,
I've got this drive:
Could anyone help me out with info on if / how this is patchable for UHD?
Many thanks
Revision: 1.00
Serial number:
Firmware date: 2019-01-07
Highest AACS version: 64
Firmware version: 1.00
Many thanks
willie3204
Hello, it looks like my drive is enabled for libredrive though its not loading the discs. Do I need to flash it?
OS device name: /dev/sr0
Product: BD-RW BDR-XS06
Revision: 1.01
Serial number: ...
Firmware date: 2015-03-24
Drive platform: RS8721
Firmware name: PIONEER BDR-XS06
No disc insertedRe: BDR-XS07S UHD Flash
PM sent.espinoza wrote: Sat May 31, 2025 5:38 pm Hi All,
Drive Information Manufacturer: PIONEER Product: BD-RW BDR-XS07 Revision: 1.00 Serial number: Firmware date: 2019-01-07 Bus encryption flags: 13 Highest AACS version: 64 LibreDrive Information Status: Enabled Drive platform: RS8E20 Firmware name: PIONEER BDR-BDS7 Firmware type: Original (unpatched) Firmware version: 1.00 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes
Many thanks![]()
