I can not rip the Godzilla Minus One Minus Color Disk from the 4 Disk Godzilla Minus One - Deluxe Edition
Here is the AACS Export
AACS v82 Blu-ray Disc Godzilla Minus One Minus Color Disk
woodworker
Re: AACS v82 Blu-ray Disc Godzilla Minus One Minus Color Disk
Did you also email this dump to svq@makemkv.com?
You can also check the keydb.cfg. Download the latest and extract it to your MakeMKV data directory. Alternatively if you're on windows, you can use my tool to sync the keydb found here:
viewtopic.php?f=12&t=16883&p=166510#p166510
