Errors ripping There Will Be Blood (3.2.0-rc5 + 1.6.16)
nickblack
Post by nickblack »
Howdy! I'm getting errors trying to decode There Will Be Blood. Here's MakeMKV.log thus far, with retries set to 10:
[skynet](0) $ cat MakeMKV_log.txt
Debug log started at Wed Dec 14 05:25:36 2011 , written by MakeMKV v1.6.16 linux(x64-release)
001005:0000 MakeMKV v1.6.16 linux(x64-release) started
001004:0000 Debug logging enabled, log will be saved as /home/dank/MakeMKV_log.txt
005072:0000 Backing up disc into folder "/media/quadtera/blurayrips/backup/THERE_WILLBE_BLOOD"
DAFD=PAAAADAAAAEABDQUEAAACATUxMjAxMiAyMTYwNDE1MDE=
DCE=9k0PgyrmSLUAnDU+sILZExBwjg8+9WsUJTqsCAhh8oTQXDVEhBImBf/dhDa7KYgL45XoLZ1FNS/j26fpm8l/YMt4tBVEVvt/zAKNvUsW38IiXCJ9Wic5kIEqEeSEfWSIl9XpQXSt14+0TAGPNNWRAJvAmdLrp/y2wA==
001003:0020 DEBUG: Code 2 at |@-!xBie;6c!Rgf=:121268719
001003:0020 DEBUG: Code 0 at Uq5N_~TL_SR(AL4UIRaOuwe:213130122
001003:0020 DEBUG: Code 199 at )HB~3#\v+$,&I]a:E:213131525
001003:0020 DEBUG: Code 1073741829 at Ct?(P?(_hxCX^/ZQ:29393953
[skynet](0) $
After long periods of 0.0X reading, it fails out on some various .m2ts file (not the same one every time).
I decoded another disc (Edward Scissorhands) between trials to ensure it wasn't an obvious problem with my drive.
Drive info:
[ 1.851386] ata8: SATA max UDMA/133 abar m2048@0xfa921000 port 0xfa921180 irq 56
[ 2.169157] ata8: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[ 2.170119] ata8.00: ATAPI: ATAPI iHBS112 2, CL0F, max UDMA/100
[ 2.171599] ata8.00: configured for UDMA/100
I'm suspecting a bad disc, but just letting you know. The errors are scattered all over the .m2ts files.
--nick black
MakeMKV_log.txt
Debug log
(2.51 KiB) Downloaded 526 times
Re: Errors ripping There Will Be Blood (3.2.0-rc5 + 1.6.16)
Post by mike admin »
Your drive reports an unknown scsi error. This is either a bad disc or drive.
