BD-RW BDR-XD05 - Read errors.
vader129
Post by vader129 »
I have been using a BD-RW BDR-XD05 drive for 10 years with very few issues reading disks. I recently tried to rip Star Trek 4 - The Voyage Home remastered, and the drive will stop reading at about 10% of the progress. Any thoughts as to what the root cause might be? I pasted the drive data below. Thanks!
OS device name: I:
Manufacturer: PIONEER
Product: BD-RW BDR-XD05
Revision: 3.01
Serial number: ...
Firmware date: 2014-12-26
Highest AACS version: 76
Drive platform: RS8231
Firmware name: PIONEER BDR-XD05
Firmware version: 3.01/ID34
Disc Information
Label: STAR_TREK_IV_TVH
Timestamp: 2021-07-15 18:00:27
Protection: AACS v76
Data capacity: 44.44 Gb
Disc type: BD-ROM
Number of layers: 2
Bus encryption flags: 80
Re: BD-RW BDR-XD05 - Read errors.
vader129 wrote: Fri Apr 18, 2025 11:23 pm I have been using a BD-RW BDR-XD05 drive for 10 years with very few issues reading disks. I recently tried to rip Star Trek 4 - The Voyage Home remastered, and the drive will stop reading at about 10% of the progress. Any thoughts as to what the root cause might be? I pasted the drive data below. Thanks!
OS device name: I:
Revision: 3.01
Serial number: ...
Disc Information
Disc type: BD-ROM
Number of layers: 2
It would be more helpful if you pasted the log window so we can see what the actual errors you are getting are but to start with, you could try cleaning the disc with a microfiber cloth. Also, the drive is old, you may need to also try cleaning the lasers.
