Billycar11 Selling Flashed Pioneer UHD Drives USA only, Remote Flashing,Tested & Makemkv Discount Code
Moviecpl15
Re: Billycar11 Selling Flashed Pioneer UHD Drives USA only, Remote Flashing,Tested & Makemkv Discount Code
#1021 Post by Moviecpl15 » Tue Apr 15, 2025 8:33 pm
Received my drive today(4/15). Already burned Super Mario Bros 4k and Obi-Wan Kenobi Series. No issues. Put in an OWC enclosure as recommended. I am fine with it sticking out a little. Drive is quiet as heck unlike my old BU04 :) Ordered on Thursday and shipped on Friday. Great Service thank you!
rynberg
#1022 Post by rynberg » Wed Apr 16, 2025 4:53 pm
Received my -212 last week, installed it in my new tower and it works great so far. Billy shipped extremely quickly and offered great communication through the whole process. Highly recommended!
Also, thanks to the posters above re: issues on the AM5 chipset. I just built a new tower, luckily the -212 is connected to a PCI-E SATA card instead of the chipset. I would have wasted countless hours trying to figure that out!
kejoki
#1023 Post by kejoki » Thu Apr 17, 2025 8:27 pm
Works exactly as expected. Painless and immediately was able to backup my 4K Matrix movies.
2 thumbs up (though can't say that for every Matrix movie...)
Memo124
#1024 Post by Memo124 » Fri Apr 18, 2025 3:26 am
What is the trick for getting the Pioneer drives to fit in the OWC Mercury Pro enclosure? I’ve seen “dremel” and “bend tabs” mentioned, but haven’t seen any details.
#1025 Post by Billycar11 » Fri Apr 18, 2025 6:43 am
Memo124 wrote: Fri Apr 18, 2025 3:26 am What is the trick for getting the Pioneer drives to fit in the OWC Mercury Pro enclosure? I’ve seen “dremel” and “bend tabs” mentioned, but haven’t seen any details.
viewtopic.php?f=16&t=19634#:~:text=Pion ... tion%20Pic
Memo124
#1026 Post by Memo124 » Fri Apr 18, 2025 10:50 am
Billycar11 wrote: Fri Apr 18, 2025 6:43 am
Ahh, thanks for adding the photo. Exactly what I was looking for.
jaredc74
#1027 Post by jaredc74 » Sat Apr 19, 2025 5:18 pm
I bought 2 drives from Billy. Drives arrived quickly and well packed. Great transaction.
badrip7
#1028 Post by badrip7 » Mon Apr 28, 2025 1:33 pm
Hi Billy, can you PM about what kind of problems have you had with the Vantec NexStar DX2? I have 2 drives that I need to determine if I need to rehome.
Mavwreck
#1029 Post by Mavwreck » Thu May 08, 2025 3:58 am
Thanks to dragonkid832 and others for info on the EAC ripping issue with Prom21 AM5 chipsets. I'm building a new PC with an MSI X670E Gaming Plus WiFi motherboard. From reading the manual it looks like the 4 SATA ports all run directly off of the chipset. I'm guessing the EAC issue will therefore affect this motherboard, right?
I had been thinking of buying one of Billy's pre-flashed BDR-212 drives. If this is the case, would it be better to put the drive in an external USB enclosure, or install a separate SATA controller in one of the PCI-E slots?
Thanks for any advice!
#1030 Post by Billycar11 » Thu May 08, 2025 11:36 am
ok everyone thank you for all the orders this past week!
60 orders a day was crazy
all upto date as of today but you guys did burned through my entire vacation supply that i was saving for later this year
SanDiegoDana
#1031 Post by SanDiegoDana » Wed May 21, 2025 1:10 am
I have an LG with an approx. 60% success rate (it works but fails part way through so you have to retry a few times). I decided to take advantage of Billycar11’s services and ordered a Pioneer 212 and it arrived quickly and worked perfectly out of the box: rip one done and looking forward to more to come.
Much thanks and highly recommended!
PS: Works great on Mac in an OWC case over USB too :)
#1032 Post by Billycar11 » Mon May 26, 2025 1:32 pm
ok everyone the last 8 s13UX i have are going up for sale
these are likely the last ones in existence with old FW that are new
Packers948
#1033 Post by Packers948 » Mon May 26, 2025 5:21 pm
Hi Billy, what kind of problems have you had with the Vantec NexStar DX2 ? I'm currently using it (got it last year 02/2024) and wondering if I should change to OWC's... Thank you
Arcluna
#1034 Post by Arcluna » Mon May 26, 2025 7:38 pm
Hi Billy, my apologies I’m new here and a little confused . How do I order? Do I just send you an email? Thank you!
#1035 Post by Billycar11 » Mon May 26, 2025 11:04 pm
Packers948 wrote: Mon May 26, 2025 5:21 pm Hi Billy, what kind of problems have you had with the Vantec NexStar DX2 ? I'm currently using it (got it last year 02/2024) and wondering if I should change to OWC's... Thank you
Pmed you
