I have multiple optical drives. Where did the setting go where each new instance would ask for which drive to use?!
UHDeezNuts
#1 Post by UHDeezNuts » Thu Apr 17, 2025 11:21 pm
I just upgraded to MakeMKV v1.18.1 on my Mac.
What happened to the setting that would make each new MakeMKV instance ask the user which drive to use? It was super useful.
I have 3 drives, and a have a disc in each drive. Each time I open a new instance it now tries to scan the same drive! The drive makes the most painful sounds as it's being scanned by 3 instances of MakeMKV at the same time! It's totally destroyed the convenience of working with multiple drives.
Was this feature removed? Or reset? Maybe I can't recall how to turn it back on.
Toad King
Re: I have multiple optical drives. Where did the setting go where each new instance would ask for which drive to use?!
#2 Post by Toad King » Thu Apr 17, 2025 11:26 pm
It should be under Settings -> IO -> Ask for single drive mode.
