The Power of Myth Blu-ray causes fatal crash
NoSignalFound
Post by NoSignalFound »
This is a new one for me. MakeMKV rips the first of four titles, then starts spitting out a ton of errors on subsequent titles until it crashes completely. The title it successfully rips appears good, but the title it's ripping on crash is just a gray square. I've successfully ripped 20+ other discs without issue on this version of MakeMKV.
Edit: this is only happening on disc 1. Disc 2 had a bunch of errors too, but all titles seem to have been successfully ripped.
Debug log started at Sun Apr 13 18:44:52 2025 , written by MakeMKV v1.18.1 darwin(arm64-release)
001005:0000 MakeMKV v1.18.1 darwin(arm64-release) started
001004:0000 Debug logging enabled, log will be saved as file:///Users/butts/MakeMKV_log.txt
Network access is ENABLED, CURL version 8.7.1/(SecureTransport) LibreSSL/3.3.6/1.63.0 (x86_64-apple-darwin24.0) , proxy server not set.
002010:0000 Optical drive "BD-RE HL-DT-ST BD-RE  WH14NS40 1.02 KL9K4B90236d" opened in OS access mode.
SDF  v098: HL-DT-ST_BD-RE__WH14NS40_1.02_211512111503_KL9K4B90236
001011:0000 Using LibreDrive mode (v06.3 id=10F16E86E12A)
DEBUG: Code 2147483648 at 3Z_2PawM&|Z!?'4q:121265499
DISCID=57667DC5C85853258BA6E7B8D0F4062C5E369250
003307:0000 File 00002.mpls was added as title #0
003307:0000 File 00004.mpls was added as title #1
003307:0000 File 00005.mpls was added as title #2
003307:0000 File 00006.mpls was added as title #3
003025:0000 Title #00002.m2ts has length of 31 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00004.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
005014:0000 Saving 1 titles into directory file:///Volumes/Storage/Rips/tpom1
005001:0308 File /Volumes/Storage/Rips/tpom1/title_t01.mkv already exist. Do you want to overwrite it?
DEBUG: Code 36036000 at 5P7]i;|F4+[!@&fQzq!]:121270168
001003:0020 DEBUG: Code 4294967295 at QLEG"BH6@5LdmBQA:k34_:121270306
001003:0020 DEBUG: Code 3956749408 at y!]_}h."c7b3fQxUI_K:213131755
001003:0020 DEBUG: Code 24002 at y!]_}h."c7b3fQxUI_K:213131778
004004:0000 The source file '/BDMV/STREAM/00017.m2ts' is corrupt or invalid at offset 129349632, attempting to work around
This goes on along with:
001003:0020 DEBUG: Code 15 at y!]_}h."c7b3fQxUI_K:121263222
001003:0020 DEBUG: Code 16 at y!]_}h."c7b3fQxUI_K:121263222
001003:0020 DEBUG: Code 17 at y!]_}h."c7b3fQxUI_K:121263222
001003:0020 DEBUG: Code 18 at y!]_}h."c7b3fQxUI_K:121263222
Last lines before crash:
DEBUG: Code 130304 at 5P7]i;|F4+[!@&fQzq!]:29402486
DEBUG: Code 3504000 at 5P7]i;|F4+[!@&fQzq!]:213138839
DEBUG: Code 18018000 at 5P7]i;|F4+[!@&fQzq!]:213138862
Re: The Power of Myth Blu-ray causes fatal crash
Its a long shot, but does the behavior change if you gently clean the disc?
NoSignalFound
dcoke22 wrote:
Mon Apr 14, 2025 3:22 pm
That's the first thing I do before I rip any disc, even if it's new (and these are).
That's a good strategy.
I don't know if it'll make a difference, but what happens if you make a decrypted backup of the disc first before trying to make .mkv files? To make a backup, on the first screen of MakeMKV, click the icon of a yellow folder with a green arrow. If it successfully makes the backup, you can open this backup in MakeMKV and create .mkv files from it.
NoSignalFound
dcoke22 wrote:
Mon Apr 14, 2025 11:38 pm
Interesting, that worked, however MakeMKV still produces a ton of errors and then crashes! It appears that it's the files themselves, not the disc. This gets me moving forward a little anyway. The unencrypted disc opens up just fine in the Blu-ray player software. Now...just have to figure out how to get these files ripped. Thanks for your help.
I wonder what it is about these files that MakeMKV doesn't like?
You can also open that decrypted backup in MKVToolNix and create .mkv files from there. I wonder if that works?
StrangeAeons
Post by StrangeAeons »
This also happened to me. I went as far as returning the first set of discs thinking they were defective. The second one I received, of course, did the same thing. I just uploaded the .m2ts files from the makemkv file backup dcoke22 suggested to Plex. They work the same as an .mkv
