BD-RE BU50N firmware flash
glorifieduk
Post by glorifieduk »
Hi everyone,
I have an external 4k BD drive that I'd like to get "Libre-drived" but I want to make sure I'm doing this right before I brick it! Here are the drive details:
OS device name: F:
Product: BD-RE BU50N
Revision: GE03
Serial number: ***********
Firmware date: 2118-01-22 14:36
Bus encryption flags: 1F
Highest AACS version: 61
I have downloaded the SDF Flash Tool v1.3.5
I have downloaded mk-firmware-pack-20200720 and can see the MK file for the BU50N in there
I have the originally generated tar file as that seems to have been useful on other posts: https://drive.google.com/drive/folders/ ... sp=sharing
From what I've read, I should now select my drive, choose WRITE, select the MK FW File and go for it?
Re: BD-RE BU50N firmware flash
glorifieduk wrote: Fri Aug 23, 2024 4:23 pm Hi everyone,
OS device name: F:
Revision: GE03
Yep
glorifieduk
Beautiful! Worked a treat and dead easy. Thanks :D
tokyojoe
Post by tokyojoe »
I have the same drive, took the same steps and everything looked good. However all my attempts to make an mkv have failed so far. I suspect the drive itself is faulty so I would like to recover the original firmware so I can return the device. Unfortunately although I did use the read option first that seems to only have the user data and I can't find the original firmware to download anywhere. Any help appreciated!
zittrig
Post by zittrig »
Post your MakeMKV drive information.
tokyojoe
Post by tokyojoe »
OS device name: F:
Revision: 1.00
Serial number: MZZJ2ID3041
Firmware date: 2117-11-21 10:06
Highest AACS version: 76
Firmware version: 1.00
tokyojoe wrote: Mon Apr 14, 2025 10:11 am Drive Information
OS device name: F:
Revision: 1.00
try BU40N 1.00
tokyojoe
Post by tokyojoe »
OK....
OS device name: F:
Product: BD-RE BU40N
Revision: 1.00
Firmware date: 2116-12-20 15:28
But now stuck at Decrypting (parsing file /AACS/MKB_RO.inf)
tokyojoe
Post by tokyojoe »
Running as admin got me past decrypting but still too many errors to get anywhere... pretty sure it's just a faulty drive at this point (having tried a lot of dvds, blu rays and uhd discs)
zittrig
Post by zittrig »
How does the mistake you receive express itself? Is an error message from MakeMKV available?
tokyojoe
Post by tokyojoe »
Error 'OS error - {Device Timeout} The specified I/O operation on hs was not completed before the time-out period expired' occurred while reading '/BDMV/STREAM/00077.m2ts' at offset '1916928000'
Error 'Internal error - Operation result is incorrect (78)' occurred while reading '\Device\CdRom0' at offset '1916928000'
Error 'OS error - {Device Timeout} The specified I/O operation on hs was not completed before the time-out period expired' occurred while reading '\Device\CdRom0' at offset '1916928000'
tokyojoe
Post by tokyojoe »
Very strange... I tried a different USB port on the same hub and it worked absolutely fine!
DavoBR
Post by DavoBR »
Lack of power from the port that failed?
pottzman
Post by pottzman »
Billycar11 wrote: Mon Apr 14, 2025 10:52 am
OS device name: F:
Revision: 1.00
try BU40N 1.00
Is there any benefits/drawbacks to picking 1 particular firmware over another. I just got myself an LG BP50NB40 that I have crossflashed to "DE_LG_BU40N_1.00.bin". the drive works fine but is there any reason for not crossflashing to "DE_LG_BU40N_1.03_MK.bin"?
pottzman wrote: Fri Oct 24, 2025 6:54 am
OS device name: F:
Revision: 1.00
try BU40N 1.00
No benefit leave it as is
