Re: Trouble Flashing New Drive on Linux
#2866 Post by Billycar11 » Fri Apr 11, 2025 7:32 pm
cdbruce1973 wrote: Fri Apr 11, 2025 3:52 pm I am on Ubuntu 24.04, just installed a BU40N ultra slim internal drive.
I am following the guide to the letter, googled and found several things to try, etc. but no matter what I do differently I always end up with the same error:
Input file not found -- /tmp/HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin
Internal error 0x83000001
Notes:
  • I am logged in as ROOT
  • I gave full access (CHMOD 777) to the sdf.bin and the HL-DT ... bin files
  • I have tried both of the commands below:
    makemkvcon f -d 'dev_21:1' -f /tmp/sdf.bin rawflash enc -i /tmp/HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin
    makemkvcon f -d 'dev_21:1' -f /tmp/sdf.bin rawflash main -i /tmp/HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin
Any help would be greatly appreciated.
Info from MakeMKV:
OS device name: /dev/sr0
Product: BD-RE BU40N
Revision: 1.02
Serial number: ,,,
Bus encryption flags: 1F
Highest AACS version: 65
Harware support: Yes
Firmware support: No
Firmware version: 1.02
Make temp match where you put those files
havok2022
#2867 Post by havok2022 » Fri Apr 11, 2025 8:19 pm
MartyMcNuts wrote: Fri Apr 11, 2025 3:01 am
havok2022 wrote: Fri Apr 11, 2025 1:49 am Looking for a new drive that can ideally rip 4K UHD BRDs, and I need an external option ideally with USB and possibly eSATA as well. USB is a bit of a must though. I'm located in the US. It didn't seem like any of the inventory in the original post were external.
Use an enclosure or SATA to USB powered adapter to use the internal desktop drives externally.
Is there a recommended enclosure? As a side note, do any of the following drives allow for ripping of 4K UHD discs?
Pioneer BDR-X13UBK
OWC Mercury Pro x16 Blu-ray
Buffalo BRXL-16U3
I'm trying to get something dual purpose so I can do disc-to-digital with my Kaleidescape and those are the three tested and confirmed drives.
JPL1984
#2868 Post by JPL1984 » Sat Apr 12, 2025 12:47 am
New here. Im looking to flash my drive and it looks like it is compatible. I have OWC mercury Pro enclosure also. Here is my drive info
BH16NS40
Revision 1.05
What firmware do i need to download and use to flash?
SidneySmi
#2869 Post by SidneySmi » Sat Apr 12, 2025 2:40 am
I'm looking for what models can be used in 2025. I don't really care about brand. I live in America.
#2870 Post by MartyMcNuts » Sat Apr 12, 2025 6:21 am
SidneySmi wrote: Sat Apr 12, 2025 2:40 am I'm looking for what models can be used in 2025. I don't really care about brand. I live in America.
See the first post.
chris996
#2871 Post by chris996 » Sat Apr 12, 2025 5:16 pm
Billycar11 wrote: Mon May 27, 2019 5:20 am Pioneer UHD drives are now supported
Great news! With this external drive I copied three UHD movies to my hard disk. One title: GLADIATOR 2000.
cdbruce1973
#2872 Post by cdbruce1973 » Sun Apr 13, 2025 2:20 pm
Billycar11 wrote: Fri Apr 11, 2025 7:32 pm
Notes:
Info from MakeMKV:
Revision: 1.02
Serial number: ,,,
Thank you for the reply - I was able to get past that error, but now whenever I run the command my Terminal just freezes up - i end up at a cursor ... doesn't flash, just sits there. No matter how long I let it sit, nothing happens until I ctrl-C to get a prompt.
Any thoughts?
liamtoh1
#2873 Post by liamtoh1 » Sun Apr 13, 2025 5:40 pm
chris996 wrote: Sat Apr 12, 2025 5:16 pm
Where are the instructions for flashing new UHD capable firmware Pioneer drives?
zittrig
#2874 Post by zittrig » Sun Apr 13, 2025 5:43 pm
Don't exists.
You need a directly support from Billycar11 or CooperVid.
Post your MakeMKV drive information, ask gently for support and wait for a reaction.
chris996
#2875 Post by chris996 » Sun Apr 13, 2025 6:58 pm
liamtoh1 wrote: Sun Apr 13, 2025 5:40 pm Where are the instructions for flashing new firmware Pioneer drives?
Okay, my mistake :) Seriously, I didn't need to flash my external Pioneer drive
to copy blu-ray movies, so I won't provide instructions.
Besides, I was afraid that I would damage the drive.
BTW. I don't know if I can give the name of the tool, I'll just write: UHD Drive Tool.
If this tool works, then very good.
Mr_Orange
#2876 Post by Mr_Orange » Sun Apr 13, 2025 9:54 pm
chris996 wrote: Sun Apr 13, 2025 6:58 pm
Sorry, your post isn't 100% clear, but are you saying that you have found/written a tool that can flash the Pioneer drives?
#2877 Post by Billycar11 » Sun Apr 13, 2025 10:17 pm
cdbruce1973 wrote: Sun Apr 13, 2025 2:20 pm
Any thoughts?
Do you have makemkv installed natively or a docker?
97Hugo
#2878 Post by 97Hugo » Mon Apr 14, 2025 12:16 pm
Hello, I was searching for information about my drive to see whether it can support 4k blu ray, but I ended up with no results. May I ask if "Buffalo BRXL-PTV6U3 SVB" is compatible in any way or form? Thanks!
Here's the information on MakeMKV
OS device name: G:
Manufacturer: BUFFALO
Product: Optical Drive
Revision: BN14
Serial number: HelloWorld
Firmware date: 2121-06-21 13:33
Highest AACS version: 81
#2879 Post by Billycar11 » Mon Apr 14, 2025 6:27 pm
97Hugo wrote: Mon Apr 14, 2025 12:16 pm Hello, I was searching for information about my drive to see whether it can support 4k blu ray, but I ended up with no results. May I ask if "Buffalo BRXL-PTV6U3 SVB" is compatible in any way or form? Thanks!
OS device name: G:
Revision: BN14
Treat it as a bu40n
97Hugo
#2880 Post by 97Hugo » Tue Apr 15, 2025 5:33 pm
Billycar11 wrote: Mon Apr 14, 2025 6:27 pm
OS device name: G:
Revision: BN14
Treat it as a bu40n
Thank you, I will try it out and see if it works!
