Make temp match where you put those filescdbruce1973 wrote: Fri Apr 11, 2025 3:52 pm I am on Ubuntu 24.04, just installed a BU40N ultra slim internal drive.
I am following the guide to the letter, googled and found several things to try, etc. but no matter what I do differently I always end up with the same error:
Input file not found -- /tmp/HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin
Internal error 0x83000001
Notes:
- I am logged in as ROOT
- I gave full access (CHMOD 777) to the sdf.bin and the HL-DT ... bin files
Any help would be greatly appreciated.
- I have tried both of the commands below:
makemkvcon f -d 'dev_21:1' -f /tmp/sdf.bin rawflash enc -i /tmp/HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin
makemkvcon f -d 'dev_21:1' -f /tmp/sdf.bin rawflash main -i /tmp/HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin
Info from MakeMKV:
OS device name: /dev/sr0
Product: BD-RE BU40N
Revision: 1.02
Serial number: ,,,
Bus encryption flags: 1F
Highest AACS version: 65
Harware support: Yes
Firmware support: No
Firmware version: 1.02
Re: Trouble Flashing New Drive on Linux
havok2022
Is there a recommended enclosure? As a side note, do any of the following drives allow for ripping of 4K UHD discs?MartyMcNuts wrote: Fri Apr 11, 2025 3:01 amUse an enclosure or SATA to USB powered adapter to use the internal desktop drives externally.havok2022 wrote: Fri Apr 11, 2025 1:49 am Looking for a new drive that can ideally rip 4K UHD BRDs, and I need an external option ideally with USB and possibly eSATA as well. USB is a bit of a must though. I'm located in the US. It didn't seem like any of the inventory in the original post were external.
Pioneer BDR-X13UBK
OWC Mercury Pro x16 Blu-ray
Buffalo BRXL-16U3
I'm trying to get something dual purpose so I can do disc-to-digital with my Kaleidescape and those are the three tested and confirmed drives.
JPL1984
New here. Im looking to flash my drive and it looks like it is compatible. I have OWC mercury Pro enclosure also. Here is my drive info
BH16NS40
Revision 1.05
What firmware do i need to download and use to flash?
BH16NS40
Revision 1.05
SidneySmi
I'm looking for what models can be used in 2025. I don't really care about brand. I live in America.
See the first post.SidneySmi wrote: Sat Apr 12, 2025 2:40 am I'm looking for what models can be used in 2025. I don't really care about brand. I live in America.
chris996
Great news! With this external drive I copied three UHD movies to my hard disk. One title: GLADIATOR 2000.
cdbruce1973
Thank you for the reply - I was able to get past that error, but now whenever I run the command my Terminal just freezes up - i end up at a cursor ... doesn't flash, just sits there. No matter how long I let it sit, nothing happens until I ctrl-C to get a prompt.Billycar11 wrote: Fri Apr 11, 2025 7:32 pmMake temp match where you put those filescdbruce1973 wrote: Fri Apr 11, 2025 3:52 pm I am on Ubuntu 24.04, just installed a BU40N ultra slim internal drive.
Notes:
Info from MakeMKV:
Revision: 1.02
Serial number: ,,,
Any thoughts?
liamtoh1
Where are the instructions for flashing new UHD capable firmware Pioneer drives?chris996 wrote: Sat Apr 12, 2025 5:16 pmGreat news! With this external drive I copied three UHD movies to my hard disk. One title: GLADIATOR 2000.
zittrig
Don't exists.
You need a directly support from Billycar11 or CooperVid.
Post your MakeMKV drive information, ask gently for support and wait for a reaction.
chris996
Okay, my mistakeliamtoh1 wrote: Sun Apr 13, 2025 5:40 pm Where are the instructions for flashing new firmware Pioneer drives?
to copy blu-ray movies, so I won't provide instructions.
Besides, I was afraid that I would damage the drive.
BTW. I don't know if I can give the name of the tool, I'll just write: UHD Drive Tool.
If this tool works, then very good.
Mr_Orange
Sorry, your post isn't 100% clear, but are you saying that you have found/written a tool that can flash the Pioneer drives?chris996 wrote: Sun Apr 13, 2025 6:58 pmOkay, my mistakeliamtoh1 wrote: Sun Apr 13, 2025 5:40 pm Where are the instructions for flashing new firmware Pioneer drives?Seriously, I didn't need to flash my external Pioneer drive
Do you have makemkv installed natively or a docker?cdbruce1973 wrote: Sun Apr 13, 2025 2:20 pm
Any thoughts?
97Hugo
Hello, I was searching for information about my drive to see whether it can support 4k blu ray, but I ended up with no results. May I ask if "Buffalo BRXL-PTV6U3 SVB" is compatible in any way or form? Thanks!
Here's the information on MakeMKV
OS device name: G:
Manufacturer: BUFFALO
Product: Optical Drive
Revision: BN14
Serial number: HelloWorld
Firmware date: 2121-06-21 13:33
Highest AACS version: 81
OS device name: G:
Revision: BN14
Treat it as a bu40n97Hugo wrote: Mon Apr 14, 2025 12:16 pm Hello, I was searching for information about my drive to see whether it can support 4k blu ray, but I ended up with no results. May I ask if "Buffalo BRXL-PTV6U3 SVB" is compatible in any way or form? Thanks!
OS device name: G:
Revision: BN14
97Hugo
Thank you, I will try it out and see if it works!Billycar11 wrote: Mon Apr 14, 2025 6:27 pmTreat it as a bu40n97Hugo wrote: Mon Apr 14, 2025 12:16 pm Hello, I was searching for information about my drive to see whether it can support 4k blu ray, but I ended up with no results. May I ask if "Buffalo BRXL-PTV6U3 SVB" is compatible in any way or form? Thanks!
OS device name: G:
Revision: BN14
