Verbatim 43890 External Slimline Mobile USB 3.2 Blu-ray Writer UHD Problem
Sagenumwoben3
Re: Verbatim 43890 External Slimline Mobile USB 3.2 Blu-ray Writer UHD Problem
Post by Sagenumwoben3 » Sat Apr 05, 2025 11:36 pm
Hi Coopervid,
Would you also help me with the firmware? Many thanks in advance.
Manufacturer: PIONEER
Product: BD-RW BDR-UD03
Revision: 1.14
Serial number: ...
Firmware date: 2020-06-15
Highest AACS version: 81
Drive platform: RS8511
Firmware version: 1.14
Post by Coopervid » Sun Apr 06, 2025 9:25 am
Sagenumwoben3 wrote: Sat Apr 05, 2025 11:36 pm Hi Coopervid,
Revision: 1.14
Serial number: ...
PM sent.
Lancery
Post by Lancery » Thu Apr 10, 2025 6:04 am
Lancery wrote: Wed Apr 02, 2025 6:57 am I am in the same boat. Is it possible for this drive to be able to support UHD? Can someone please help? TIA.
OS device name: F:
Current profile: DVD-ROM
Revision: 1.14
Serial number: ...
Highest AACS version: 12
Coopervid, any chance I could get your help on this too? Thanks in advance!
IamHerk
Post by IamHerk » Thu Apr 10, 2025 3:52 pm
Hi Coopervid,
Thank you for helping us with our 43890 drives. Can I get your help on the firmware as well. Here's my drive info...
IamHerk
OS device name: F:
Revision: 1.14
Serial number: ...
Post by Coopervid » Fri Apr 11, 2025 4:08 pm
IamHerk wrote: Thu Apr 10, 2025 3:52 pm Hi Coopervid,
IamHerk
OS device name: F:
Revision: 1.14
Serial number: ...
PM sent.
chris996
Post by chris996 » Sat Apr 12, 2025 3:03 pm
I'm using Verbatim UHD Blu-ray Writer. I have original (unpatched) version.
With this writer I copied the entire movie to my hard disk. Title: GLADIATOR 2000.
So the product is definitely worth recommending.
jacknw
Post by jacknw » Sun Apr 13, 2025 4:57 am
Hi Coopervid,
Can you help share the firmware with me as well? Would really appreciate your help on that.
OS device name: F:
Revision: 1.14
Serial number: ...
IamHerk
Post by IamHerk » Mon Apr 14, 2025 5:20 pm
Coopervid wrote: Fri Apr 11, 2025 4:08 pm
IamHerk
OS device name: F:
Revision: 1.14
Serial number: ...
PM sent.
Thank you very much, the flash worked perfectly.
IamHerk
bobburger
Post by bobburger » Wed Apr 30, 2025 6:55 pm
I'm also struggling with this on my 43890 Blu-ray writer. Any help appreciated!
OS device name: G:
Product: BD-RW BDR-UD04
Revision: 1.14
Serial number: DDDL526178WL
Drive platform: RS8A10
Post by Coopervid » Wed Apr 30, 2025 7:58 pm
bobburger wrote: Wed Apr 30, 2025 6:55 pm I'm also struggling with this on my 43890 Blu-ray writer. Any help appreciated!
OS device name: G:
Revision: 1.14
Your drive is UHD enabled. However, these Verbatim enclosures are power hungry. Connect to USB3 or use a powered USB hub.
bobburger
Post by bobburger » Wed Apr 30, 2025 8:34 pm
Coopervid wrote: Wed Apr 30, 2025 7:58 pm
OS device name: G:
Revision: 1.14
Thanks for the quick reply. I have it now plugged into a USB3 with the dedicated power cable attached as well but it's still failing to read the disc. When inserted it starts to spin, with disc information showing "Disc is being loaded" but eventually gives me the same output as before.
Post by Coopervid » Wed Apr 30, 2025 10:38 pm
bobburger wrote: Wed Apr 30, 2025 8:34 pm
OS device name: G:
Revision: 1.14
Wash the disc even if it is brand new. Try again. Clean your laser lens with a CD cleaning disc.
Post by Billycar11 » Thu May 01, 2025 7:12 am
always let your os see the disc first then open makemkv do not have it opened first this sometimes causes conflicts
jinx100
Post by jinx100 » Thu May 01, 2025 7:52 pm
I have a couple Verbatim 43890 drives and they came with external power bricks. Have you tried using this external power source? I use that and it runs fine with single USB 2.0 connection.
Like Coopervid says, clean the disc. I've had new discs come with an oily film. Sometimes the disc is just defective, too.
babywinchester
Post by babywinchester » Fri May 02, 2025 4:26 am
Hey Coopervid
I have the same drive as well and need your help in reading UHD
please can you help me with the same would be obliged really
