I'm backing up a 2 disc blu-ray from an iso. The first disc was fine but the second disc throws an error: Failed to open disc.
The debug log says this:
Debug log started at Mon Mar 31 20:53:40 2025 , written by MakeMKV v1.17.9 win(x64-release)
001005:0000 MakeMKV v1.17.9 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as file://C:\Users\Lee/MakeMKV_log.txt
005042:0000 The program can't find any usable optical drives.
003006:0000 Opening files on harddrive at file://F:/Video Concerts/VA - Crossroads Eric Clapton Guitar Festival 2013 (Disc 1)/2013 - Crossroads Guitar Festival Eric Clapton Disc 2 (2 Blu-ray, 0349790772)/2013 - Crossroads Guitar Festival Eric Clapton (2 Blu-ray, 0349790772)/Crossroads 2013 Disc 2
001003:0020 DEBUG: Code 0 at cCo\%.pGLJ5viS:29408581
001003:0020 DEBUG: Code 0 at J`yG~z~op# ?&/i}:29398875
001003:0020 DEBUG: Code 0 at J`yG~z~op# ?&/i}:121263682
001003:0020 DEBUG: Code 0 at J`yG~z~op# ?&/i}:121263084
Application exited at Mon Mar 31 20:55:34 2025
Can anyone figure out what's happening and suggest a solution?
Thanks.
Failed to Open Disc
Re: Failed to Open Disc
There's probably something wrong with how the ISO was created. I'm just guessing.
letting1
Thanks for the reply. You could be right. I got the same sort of error on another ISO, but it may be the same cause - ISO not created correctly.
kstiggs
I am all of a sudden getting "Failed to open disc errors on every disc I try. The drive reads the discs fine and they are in good shape. Title comes up in the Label section at the top. I don't know what to do, please help.
updated to MakeMKV v 1.18.1 [win(x64-release)]
DEBUG: Code 3221225664 at e!/TsMgD>)UEE`0S:121267293
Error 'Scsi error - NOT READY:LOGICAL UNIT IS IN PROCESS OF BECOMING READY' occurred while reading 'BD-RE HL-DT-ST BD-RE BP60NB10 1.00 SIM2221L01700' at offset '524288'
Error 'Scsi error - NOT READY:LOGICAL UNIT IS IN PROCESS OF BECOMING READY' occurred while reading 'BD-RE HL-DT-ST BD-RE BP60NB10 1.00 SIM2221L01700' at offset '1048576'
Error 'Scsi error - NOT READY:LOGICAL UNIT IS IN PROCESS OF BECOMING READY' occurred while reading 'BD-RE HL-DT-ST BD-RE BP60NB10 1.00 SIM2221L01700' at offset '32768'
OS device name: H:
Product: BD-RE BP60NB10
Revision: 1.00
Serial number: SIM2221L01700
Firmware date: 2117-11-21 17:20
Highest AACS version: 81
Firmware version: 1.00
Disc Information
Label: Stranger_Things_S1_D1
Timestamp: 2017-08-31 12:05:27
Protection: AACS v63
Data capacity: 45.86 Gb
Disc type: BD-ROM
Number of layers: 2
OS device name: H:
Revision: 1.00
Disc Information
Disc type: BD-ROM
Number of layers: 2
The drive probably isn't getting enough power. If it is powered by USB, make sure all the USB plugs are in high powered ports.
kstiggs
Wow you all are so smart and such a lifesaver!!! That seems to have worked. I did change my USB setup around. Oddly I was able to do two movies before this issue started occurring. Should probably check the quality of those two.
Thanks so much!!!!!!
