My Drive Sometimes Becomes Unusable
ezzieyguywuf
#1 Post by ezzieyguywuf » Fri Apr 11, 2025 7:47 pm
I've had success using the makemkvcon command-line utility to rip single tracks at a time. when I try to rip an entire disc at once though, I'll inevitably get a kernel-level error and the drive becomes unusable until I power cycle my computer. Here is the info from makemkv:
Información de unidad de disco
Nombre del SO del dispositivo: /dev/sr0
Perfil actual: DVD-ROM
Fabricante: PIONEER
Producto: BD-RW BDR-212D
Revisión: 1.02
Número de serie: ...
Fecha del firmware: 2022-03-16
Marcas de cifrado bus: 13
Drive platform: RS8F00
Firmware version: 1.02/ID61
Información de disco
Etiqueta: BOONDOCKS_SEASON_ONE_DISC_ONE
Marca de tiempo: 2006-05-31 08:56:28
Protección: CSS/CPPM
Capacidad: 7.29 Gb
Tipo de disco: DVD-ROM
Tamaño de disco: 120mm
Velocidad máxima de lectura: 10.08 Mbps [1x]
Número de capas: 2 (OTP)
I don't have access to the PC with the optical drive right at this moment so I can't paste in the system log errors I mentioned, but I do recall noticing (while browsing the logs) that it would frequently do a "hard reset" of the device while ripping, and eventually it was unable to do this reset and then /dev/sr0 was no longer available until a power cycle.
what can I do to further triage this issue? is there a way to enable additional logs from makemkv?
Re: My Drive Sometimes Becomes Unusable
#2 Post by dcoke22 » Tue Apr 15, 2025 1:59 pm
Is the drive in an enclosure? Is it getting plenty of power?
