Dump Submitted - SALUT_L_AMI_ADIEU_TRESOR 4K UHD TGZ Key File
Tihany
Submitted dump: MKB20_v82_SALUT_L_AMI_ADIEU_TRESOR_FFE6.tgz
keydb_helper
Re: Dump Submitted - SALUT_L_AMI_ADIEU_TRESOR 4K UHD TGZ Key File
Thank you for providing your disc dump file. I believe that is the first known MKBv82 AACS2 disc.
The FFE6 variant of Salut l'ami, adieu le trésor has been added to the public keydb.
If you haven't previously configured MakeMKV to utilise the public keydb you can follow my instructions here or use SamuriHL's utility for Windows (Link)
Public KeyDB Disc Submissions
- The MKB_RO.inf file from the original disc is required
- Do not submit Stranger Things
Tihany
Cool, that's great! Thank you very much!keydb_helper wrote: Fri Apr 11, 2025 4:35 pmThank you for providing your disc dump file. I believe that is the first known MKBv82 AACS2 disc.
