Impossible to rip my burned dvd's
Ronken
Post by Ronken » Wed Oct 21, 2009 6:37 pm
I am trying to rip my entire dvd collection. I have no problem doing this with the retails I own, but when I try to do it with my iso-backup dvd's, the program can't read them or freezes. Why??
Ronken
Re: Impossible to rip my burned dvd's
Post by Ronken » Fri Oct 23, 2009 7:26 pm
Nobody knows? I am alone with this problem?
cyrdog
Post by cyrdog » Tue Oct 27, 2009 2:57 pm
I'm having the same issue trying to read ISOs using the Mac version of MakeMKV. The program always crashes with a fatal error after a few seconds of reading the ISO file and generating the output MKV file.
cyrdog
Post by cyrdog » Tue Oct 27, 2009 3:01 pm
Here are 2 examples of my log files trying to convert 2 different ISO files:
Debug log started at Tue Oct 27 14:57:31 2009 , written by MakeMKV v1.4.8 beta darwin(x86-release)
001014:000000:0000 MakeMKV v1.4.8 beta darwin(x86-release) started
001013:000000:0000 Debug logging enabled, log will be saved as /Users/Mark/MakeMKV_log.txt
001012:000000:0020 FAILURE: Code 0 at %$K'7k/|wNr!5t\jn#?F9B<s@CM:121264878
003010:000000:0000 Using direct disc access mode
003310:000000:0000 AACS directory not present, assuming unencrypted disc
003313:000000:0000 File 00000.mpls was added as title #0
005011:000000:0000 Operation sucessfully completed
005014:000000:0000 Saving 1 titles into directory /Users/Mark/Desktop
001012:000000:0020 FAILURE: Code 2147483647 at cEAA|'u{_hN9%;Hx7So:121261474
Debug log started at Tue Oct 27 15:00:16 2009 , written by MakeMKV v1.4.8 beta darwin(x86-release)
005001:000000:0308 File /Users/Mark/Desktop/title00.mkv already exist. Do you want to overwrite it?
001012:000000:0020 FAILURE: Code 3235046876 at ;48]N:"$RtN]o-is"8}:121262578
001012:000000:0020 FAILURE: Code 208 at ;48]N:"$RtN]o-is"8}:121262417
001012:000000:0020 FAILURE: Code 0 at Ki[$9xEvae-@2&CECQJW_:121264211
Post by mike admin » Wed Oct 28, 2009 8:29 am
Thank you for reporting this. Two questions:
1. How was original ISO produced - was it direct copy or some other decryption software.
2. Can you please open the iso again, select the same title(s) but unselect all subtitles, try to save and post the result here.
