Issue with MakeMKV 1.16.5 on M1 Macs running macOS Monterey (needs code signing)
gorlak
Re: Issue with MakeMKV 1.16.5 on M1 Macs running macOS Monterey (needs code signing)
Post by gorlak » Sun Jul 28, 2024 3:50 pm
Running Sonoma 14.5 and 1.17.7 on a Macbook Pro M1 and I'm seeing this dialog.
I followed the prior post's instructions to clear out all old versions. It worked for 5-6 discs, then it started prompting on every disk again.
ripthem
Post by ripthem » Wed Apr 09, 2025 12:28 pm
I have the same issue.
This is on a Mac Mini M1, macOS 15.3.2 (cannot write or speak the name of this OS version)
I read those topics too:
viewtopic.php?f=4&t=34855&p=157091&hili ... me#p157091
viewtopic.php?f=1&t=30473&p=134192&hili ... me#p134192
I removed MakeMKV and makemkv from both Files & Folders and Full Disk Access menus.
Then re-added MakeMKV to Full Disk Access, started the application and ripped a Bluray to a Thunderbolt enclosure, I then got asked about the "removable volumes" and choose "OK".
This created the makemkv entry below Files & Folders, mentioning "Removable Volumes".
But it did NOT add "Removable Volumes" to MakeMKV!
So I did refresh any configuration I could and this SHOULD help!
At the next disk, without exiting the application, I did not get the question again!
I will watch this and report back, when I get this question again.
ripthem
Post by ripthem » Thu Apr 10, 2025 3:35 pm
That was fast.
It definitely keeps coming back!
I exited makemkv yesterday and today started it again.
An bamm, the question is back!
And NOT just for the first time, but for each and any disk!
Is there nothing the developers can do against this?
This is so unbearable and not logical ...
