Dump Submitted - SALUT_L_AMI_ADIEU_TRESOR 4K UHD TGZ Key File
Tihany
Post by Tihany »
Submitted dump: MKB20_v82_SALUT_L_AMI_ADIEU_TRESOR_FFE6.tgz
keydb_helper
Re: Dump Submitted - SALUT_L_AMI_ADIEU_TRESOR 4K UHD TGZ Key File
Post by keydb_helper »
Tihany wrote:
Thu Apr 10, 2025 2:11 pm
Thank you for providing your disc dump file. I believe that is the first known MKBv82 AACS2 disc.
The FFE6 variant of Salut l'ami, adieu le trésor has been added to the public keydb.
If you haven't previously configured MakeMKV to utilise the public keydb you can follow my instructions here or use SamuriHL's utility for Windows (Link)
Public KeyDB Disc Submissions
  • LG/Buffalo/Asus drives only (Pioneer drives are not supported)
  • If your disc dump is under 3MB, you need to manually include the MKB_RO.inf file from the AACS folder
Tihany
Post by Tihany »
keydb_helper wrote:
Fri Apr 11, 2025 4:35 pm
Cool, that's great! Thank you very much!
