Friends with Benefits
Dutch69
Post by Dutch69 »
When I use MakeMKV version 1.6.16 I get a file with 121 chapters. When I review the disc on my Blu-Ray player it shows 16 chapters.
Anybody else have this issue, or is just me???
setarip_old
Re: Friends with Benefits
Post by setarip_old »
Hi!
Are you sure you don't mean "A folder containing 121 files"?
Dutch69
Post by Dutch69 »
Nope I want to say chapters. The movie says and shows 121 very short chapters when I watch the MKV file as I can jump to each one, when I review the actual Blu-ray disk it only has 16 movie chapters to jump around on when playing the movie.
Post by mike admin »
Can you please post mediainfo output for the mkv file? Please confirm that you're converting a blu-ray disc, not DVD.
Dutch69
Post by Dutch69 »
Sorry for being a little on the slow side, but can you give me a hint were to find the file you requested.
In the mean time I made a screen grab of what I see when I get ready to try and make a MKV file, it is a Blu-Ray disc.
Also I did hit the please let us know link. As soon I understand what file you would I will upload it for you.
I’m glad I paid your registration fee as this has been a great tool.
Thank you again for your help.
MakeMKV Friends with B.jpg (281.16 KiB) Viewed 28023 times
crowfax
Post by crowfax »
MediaInfo for this movie (I remuxed it with MKVmergeGUI to fix the issue my WD TV has with PGS subtitles but nothing else was changed).
General
Unique ID                        : 185009740690693160547234881053056801328 (0x8B2F9478416460C289B1B715B7979A30)
Complete name                    : E:\Blu-ray\Friends With Benefits.mkv
Format                           : Matroska
Format version                   : Version 2
File size                        : 20.2 GiB
Duration                         : 1h 49mn
Overall bit rate mode            : Variable
Overall bit rate                 : 26.5 Mbps
Encoded date                     : UTC 2011-12-08 03:15:46
Writing application              : mkvmerge v5.1.0 ('And so it goes') built on Nov 28 2011 23:58:28
Writing library                  : libebml v1.2.3 + libmatroska v1.3.0
Video
Format                           : AVC
Format/Info                      : Advanced Video Codec
Format profile                   : High@L4.1
Format settings, CABAC           : Yes
Format settings, ReFrames        : 2 frames
Codec ID                         : V_MPEG4/ISO/AVC
Duration                         : 1h 49mn
Bit rate mode                    : Variable
Bit rate                         : 24.4 Mbps
Width                            : 1 920 pixels
Height                           : 1 080 pixels
Display aspect ratio             : 16:9
Frame rate                       : 23.976 fps
Color space                      : YUV
Chroma subsampling               : 4:2:0
Bit depth                        : 8 bits
Scan type                        : Progressive
Bits/(Pixel*Frame)               : 0.491
Stream size                      : 18.7 GiB (92%)
Language                         : English
Default                          : Yes
Forced                           : No
Audio
Format                           : DTS
Format/Info                      : Digital Theater Systems
Codec ID                         : A_DTS
Duration                         : 1h 49mn
Bit rate mode                    : Constant
Bit rate                         : 1 510 Kbps
Channel(s)                       : 6 channels
Channel positions                : Front: L C R, Side: L R, LFE
Sampling rate                    : 48.0 KHz
Bit depth                        : 16 bits
Compression mode                 : Lossy
Stream size                      : 1.15 GiB (6%)
Title                            : 3/2+1
Language                         : English
Default                          : Yes
Forced                           : No
Text
Format                           : PGS
Muxing mode                      : zlib
Codec ID                         : S_HDMV/PGS
Codec ID/Info                    : The same subtitle format used on BDs/HD-DVDs
Language                         : English
Default                          : No
Forced                           : No
Menu
00:00:00.000                     : en:Chapter 00
00:00:06.339                     : en:Chapter 01
00:00:15.473                     : en:Chapter 02
00:00:27.277                     : en:Chapter 03
00:00:36.745                     : en:Chapter 04
00:00:48.089                     : en:Chapter 05
00:00:57.932                     : en:Chapter 06
00:01:27.462                     : en:Chapter 07
00:01:45.063                     : en:Chapter 08
00:01:59.244                     : en:Chapter 09
00:02:25.687                     : en:Chapter 10
00:03:11.441                     : en:Chapter 11
00:03:49.437                     : en:Chapter 12
00:04:24.305                     : en:Chapter 13
00:04:42.949                     : en:Chapter 14
00:04:50.915                     : en:Chapter 15
00:05:12.270                     : en:Chapter 16
00:05:36.711                     : en:Chapter 17
00:05:52.310                     : en:Chapter 18
00:06:22.340                     : en:Chapter 19
00:07:34.412                     : en:Chapter 20
00:08:41.771                     : en:Chapter 21
00:10:16.282                     : en:Chapter 22
00:10:28.878                     : en:Chapter 23
00:10:47.104                     : en:Chapter 24
00:11:44.078                     : en:Chapter 25
00:12:17.695                     : en:Chapter 26
00:13:42.071                     : en:Chapter 27
00:13:54.166                     : en:Chapter 28
00:14:59.607                     : en:Chapter 29
00:15:47.029                     : en:Chapter 30
00:16:21.105                     : en:Chapter 31
00:17:03.981                     : en:Chapter 32
00:17:50.319                     : en:Chapter 33
00:18:33.445                     : en:Chapter 34
00:19:04.143                     : en:Chapter 35
00:19:19.032                     : en:Chapter 36
00:20:26.308                     : en:Chapter 37
00:21:25.867                     : en:Chapter 38
00:21:50.809                     : en:Chapter 39
00:22:17.002                     : en:Chapter 40
00:23:04.007                     : en:Chapter 41
00:23:51.138                     : en:Chapter 42
00:24:34.222                     : en:Chapter 43
00:25:19.643                     : en:Chapter 44
00:26:19.578                     : en:Chapter 45
00:26:49.899                     : en:Chapter 46
00:27:14.549                     : en:Chapter 47
00:27:53.171                     : en:Chapter 48
00:28:40.009                     : en:Chapter 49
00:29:18.339                     : en:Chapter 50
00:30:31.704                     : en:Chapter 51
00:31:20.670                     : en:Chapter 52
00:33:11.739                     : en:Chapter 53
00:34:00.705                     : en:Chapter 54
00:34:53.424                     : en:Chapter 55
00:35:50.439                     : en:Chapter 56
00:36:27.518                     : en:Chapter 57
00:36:54.170                     : en:Chapter 58
00:38:59.462                     : en:Chapter 59
00:41:29.570                     : en:Chapter 60
00:42:48.607                     : en:Chapter 61
00:44:11.899                     : en:Chapter 62
00:44:31.377                     : en:Chapter 63
00:45:00.072                     : en:Chapter 64
00:46:02.676                     : en:Chapter 65
00:46:28.202                     : en:Chapter 66
00:47:10.661                     : en:Chapter 67
00:47:27.261                     : en:Chapter 68
00:47:46.738                     : en:Chapter 69
00:48:07.718                     : en:Chapter 70
00:49:13.075                     : en:Chapter 71
00:50:10.674                     : en:Chapter 72
00:51:04.478                     : en:Chapter 73
00:52:08.917                     : en:Chapter 74
00:54:07.035                     : en:Chapter 75
00:54:50.954                     : en:Chapter 76
00:56:43.191                     : en:Chapter 77
00:57:16.558                     : en:Chapter 78
00:59:14.968                     : en:Chapter 79
00:59:49.502                     : en:Chapter 80
01:00:31.336                     : en:Chapter 81
01:00:52.649                     : en:Chapter 82
01:02:29.537                     : en:Chapter 83
01:02:55.897                     : en:Chapter 84
01:03:36.145                     : en:Chapter 85
01:05:09.196                     : en:Chapter 86
01:08:05.623                     : en:Chapter 87
01:08:27.520                     : en:Chapter 88
01:09:58.527                     : en:Chapter 89
01:11:10.266                     : en:Chapter 90
01:12:10.868                     : en:Chapter 91
01:14:06.108                     : en:Chapter 92
01:14:49.776                     : en:Chapter 93
01:15:14.801                     : en:Chapter 94
01:17:01.408                     : en:Chapter 95
01:18:33.542                     : en:Chapter 96
01:19:57.709                     : en:Chapter 97
01:21:16.454                     : en:Chapter 98
01:21:54.951                     : en:Chapter 99
01:23:31.423                     : en:Chapter 100
01:24:36.196                     : en:Chapter 101
01:26:06.703                     : en:Chapter 102
01:27:03.218                     : en:Chapter 103
01:28:13.997                     : en:Chapter 104
01:29:02.337                     : en:Chapter 105
01:29:51.636                     : en:Chapter 106
01:30:53.156                     : en:Chapter 107
01:31:01.998                     : en:Chapter 108
01:32:00.890                     : en:Chapter 109
01:32:38.511                     : en:Chapter 110
01:33:24.849                     : en:Chapter 111
01:35:31.100                     : en:Chapter 112
01:36:02.423                     : en:Chapter 113
01:36:48.469                     : en:Chapter 114
01:38:09.758                     : en:Chapter 115
01:38:33.657                     : en:Chapter 116
01:39:34.009                     : en:Chapter 117
01:41:04.433                     : en:Chapter 118
01:41:24.286                     : en:Chapter 119
01:42:32.813                     : en:Chapter 120
So, the output file has 120 chapters. Seems the problem is with your player, it is unable to display that many chapters.
On the other note, PLEASE, PLEASE, PLEASE send the file called MKB_RO.inf from this disc to support@makemkv.com . The file is inside "AACS" folder and should be easily compressed with any archiver.
crowfax
Post by crowfax »
Ok. I shall send the file this evening.
Dutch69
Post by Dutch69 »
Mike I am trying to find what you requested but I searched my computer and I can not find the information you requested. Neither the file called MKB_RO.inf or "AACS” folder can be found on my Mac.
I am opening to suggestions if you have anything you want me to try.
crowfax
Post by crowfax »
I've emailed the file.
crowfax
Post by crowfax »
I can confirm from having looked at the menu on the disc for "scene selection" as well as using TMT5's own "right click" -> "chapters" menu that it does appear to only have 16 chapters, yet MakeMKV reports 120. Here is the mediaInfo from a fresh rip:
General
Unique ID                        : 45823034641796006234602554837140100431 (0x2279320966676D71F0024EBCCE95D54F)
Complete name                    : C:\Users\matt\Videos\MKV\Friends_with_Benefits_-_Blu-ray\title01.mkv
Format                           : Matroska
File size                        : 20.4 GiB
Duration                         : 1h 49mn
Overall bit rate                 : 26.6 Mbps
Encoded date                     : UTC 2011-12-21 17:55:09
Writing application              : MakeMKV v1.6.16 win(x64-release)
Writing library                  : libmakemkv v1.6.16 (1.2.0/1.1.0) win(x64-release)
Video
Format                           : AVC
Duration                         : 1h 49mn
Bit rate                         : 24.6 Mbps
Color space                      : YUV
Bit depth                        : 8 bits
Bits/(Pixel*Frame)               : 0.495
Stream size                      : 18.8 GiB (92%)
Language                         : English
Default                          : Yes
Forced                           : No
Audio
Format                           : DTS
Codec ID                         : A_DTS
Duration                         : 1h 49mn
Bit depth                        : 16 bits
Title                            : 3/2+1
Language                         : English
Default                          : Yes
Forced                           : No
Text #1
Format                           : PGS
Language                         : English
Default                          : Yes
Forced                           : No
Text #2
Format                           : PGS
Language                         : English
Default                          : No
Forced                           : No
Text #3
Format                           : PGS
Language                         : English
Default                          : No
Forced                           : No
Menu
Dutch69
Post by Dutch69 »
Crowfax thanks for your help getting the information submitted!!!
robpdotcom
Post by robpdotcom »
I've seen this on a few discs lately. There are two playlists that contain the entire movie - one has the correct number of chapters, the other has 100+. The workaround I used is to use eac3to to demux the disc, and manually select the correct playlist.
robpdotcom wrote:I've seen this on a few discs lately. There are two playlists that contain the entire movie - one has the correct number of chapters, the other has 100+. The workaround I used is to use eac3to to demux the disc, and manually select the correct playlist.
That's it, for two otherwise identical titles MakeMKV always selects one with the bigger chapter count. Please send all CLPI and MPLS files from this disc per instructions at http://www.makemkv.com/faq/item/8/catid/6
crowfax
Post by crowfax »
Files emailed.
