I'll admit I'm a little confused on the LibreDrive and KEYDB.cfg
for context , I purchased a pioneer BDR-212DBK recently, and I'm interested in using it to back up my DVD and Blu-ray collection.
at the time of purchase I did not realize that both DVD and Blu-ray used encryption/ drm, though I guess the protection has been cracked for dvd. my understanding is that Blu-ray uses some updated data on newer discs to prevent such cracking
my confusion lies in: what do I need to do to backup my collection? do I just need a KEYDB.cfg? how often do I update it? do I also need LibreDrive? or are the two used in concert? does my drive support LibreDrive? how do I check the version of firmware I have?
I am using Linux of that makes any difference. thank you for any help.
Pioneer BDR-212DBK is this Libre drive?
Re: Pioneer BDR-212DBK is this Libre drive?
Post your Makemkv info.ezzieyguywuf wrote: Thu Apr 10, 2025 3:11 am I'll admit I'm a little confused on the LibreDrive and KEYDB.cfg
ezzieyguywuf
Is this the makemkv info you're talking about?
Información de unidad de disco
Nombre del SO del dispositivo: /dev/sr0
Perfil actual: DVD-ROM
Fabricante: PIONEER
Producto: BD-RW BDR-212D
Revisión: 1.02
Número de serie: CIDL052829WL
Fecha del firmware: 2022-03-16
Marcas de cifrado bus: 13
Drive platform: RS8F00
Firmware version: 1.02/ID61
Información de disco
Etiqueta: BOONDOCKS_SEASON_ONE_DISC_ONE
Marca de tiempo: 2006-05-31 08:56:28
Protección: CSS/CPPM
Capacidad: 7.29 Gb
Tipo de disco: DVD-ROM
Tamaño de disco: 120mm
Velocidad máxima de lectura: 10.08 Mbps [1x]
Número de capas: 2 (OTP)-
LibreDrive Informationezzieyguywuf wrote: Fri Apr 11, 2025 1:04 am Is this the makemkv info you're talking about?
Información de unidad de disco Nombre del SO del dispositivo: /dev/sr0 Perfil actual: DVD-ROM Fabricante: PIONEER Producto: BD-RW BDR-212D Revisión: 1.02 Número de serie: CIDL052829WL Fecha del firmware: 2022-03-16 Marcas de cifrado bus: 13 LibreDrive Information Status: Enabled Drive platform: RS8F00 Firmware name: PIONEER BDR-212T Firmware type: Original (unpatched) Firmware version: 1.02/ID61 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes Información de disco Etiqueta: BOONDOCKS_SEASON_ONE_DISC_ONE Marca de tiempo: 2006-05-31 08:56:28 Protección: CSS/CPPM Capacidad: 7.29 Gb Tipo de disco: DVD-ROM Tamaño de disco: 120mm Velocidad máxima de lectura: 10.08 Mbps [1x] Número de capas: 2 (OTP)
That drive will work fine as is for DVD/BD discs. It can also be flashed to enable UHD ripping if needed.
alexbar
[/quote]
but it will also work as UHD playback?
[/quote]
but it will also work as UHD playback?alexbar wrote: Tue May 13, 2025 10:12 am That drive will work fine as is for DVD/BD discs. It can also be flashed to enable UHD ripping if needed.
[/quote]
Official playback, no, never.
Unofficial UHD playback, sure. Just integrate VLC, MPC-HC or whatever player with MakeMKV as it is used as the on-the-fly decrypter.
Direct UHD disc playback is not recommended as it will wear out your drive quite a bit faster.
alexbar
Official playback, no, never.MartyMcNuts wrote: Tue May 13, 2025 10:18 ambut it will also work as UHD playback?alexbar wrote: Tue May 13, 2025 10:12 am That drive will work fine as is for DVD/BD discs. It can also be flashed to enable UHD ripping if needed.
[/quote]
direct playback, do you mean unofficial playback? Is it the same with official UHD drives?
direct playback, do you mean unofficial playback? Is it the same with official UHD drives?alexbar wrote: Tue May 13, 2025 10:39 amOfficial playback, no, never.MartyMcNuts wrote: Tue May 13, 2025 10:18 ambut it will also work as UHD playback?alexbar wrote: Tue May 13, 2025 10:12 am That drive will work fine as is for DVD/BD discs. It can also be flashed to enable UHD ripping if needed.
[/quote]
These days there is no official playback method as most people don't have an older Intel CPU with sgx and the old version of Powerdvd that still had UHD playback ability.
Cyberlink removed UHD playback from PowerDVD a few years ago now so there's no longer any official UHD playback software. So, the only way to play a UHD disc is using an unofficial player such as VLC, MPC-HC etc.
By direct disc playback, I mean exactly that. It is not recommended to play UHD discs at all. It is best to rip them and then play the ripped file(s).
Toscaclarinet
These days there is no official playback method as most people don't have an older Intel CPU with sgx and the old version of Powerdvd that still had UHD playback ability.MartyMcNuts wrote: Tue May 13, 2025 10:47 amdirect playback, do you mean unofficial playback? Is it the same with official UHD drives?alexbar wrote: Tue May 13, 2025 10:39 amOfficial playback, no, never.
[/quote]
Why does playing discs wear out the drive faster than ripping them? I would have thought it was the other way round, since ripping is at faster speeds than playing so more likely to wear out the components.
Why does playing discs wear out the drive faster than ripping them? I would have thought it was the other way round, since ripping is at faster speeds than playing so more likely to wear out the components.Toscaclarinet wrote: Sat May 17, 2025 11:34 amThese days there is no official playback method as most people don't have an older Intel CPU with sgx and the old version of Powerdvd that still had UHD playback ability.MartyMcNuts wrote: Tue May 13, 2025 10:47 amdirect playback, do you mean unofficial playback? Is it the same with official UHD drives?alexbar wrote: Tue May 13, 2025 10:39 am
[/quote]
Well, if you rip it, you are only using the disc and the drive once. If you just play it, you may use the disc and the drive multiple times. Then multiply that by your 4k UHD collection and it adds up!
Better to rip the disc the first time. This way, you are saving the disc from possible scratches etc and the drive from additional wear and tear. Yes, ripping does read a little faster than playback but that's no biggie.
