Verbatim 43888 is BU40N drive from Amazon US
Mathematics
#1 Post by Mathematics » Wed Apr 09, 2025 8:49 pm
Apparently it's "hit or miss" in trying to get the Verbatim 43888 drive with the Pioneer hardware, but I just wanted to let people know that today, April 9, 2025, Amazon sent me a Verbatim drive with the following:
OS device name: F:
Product: BD-RE BU40N
Revision: 1.05
Serial number: MOFOAMA####
Highest AACS version: 76
I already have an LG and Pioneer drive but I was hoping to get another Pioneer. Oh well.
uhd4k
Re: Verbatim 43888 is BU40N drive from Amazon US
#2 Post by uhd4k » Wed Apr 09, 2025 10:33 pm
Can you please share the Amazon link?
Also, you wrote that you were hoping to get one with Pioneer hardware, but if you did, wouldn't you have an issue with the new Pioneer firmware?
Thanks.
Mathematics
#3 Post by Mathematics » Thu Apr 10, 2025 12:51 am
uhd4k wrote: Wed Apr 09, 2025 10:33 pm Can you please share the Amazon link?
https://www.amazon.com/dp/B07MTP9VKX?re ... title&th=1
uhd4k wrote: Wed Apr 09, 2025 10:33 pm Also, you wrote that you were hoping to get one with Pioneer hardware, but if you did, wouldn't you have an issue with the new Pioneer firmware?
I read on other posts that the sought-after drive was already flashed and ready-to-go. Unfornately, that didn't happen to me and I'm not going to try anymore. I'm just sticking with what I have now and hope that my drives outlast this drought of 4K capable Pioneer drives. In time, I'm sure this will be a thing of the past, and ripping UHD movies will be as easy as ripping CDs.
To future-proof my media ecosystem, I may purchase another Pioneer drive from sellers here and on eBay.
burnbaby
#4 Post by burnbaby » Thu Apr 10, 2025 12:53 am
I got the exact drive with the odd 2124 firmware date. It will not backup a 4K. Is it possible to flash this drive? From other posts it seems once it's on a newer firmware you can't go back.
#5 Post by MartyMcNuts » Thu Apr 10, 2025 12:58 am
Mathematics wrote: Wed Apr 09, 2025 8:49 pm Apparently it's "hit or miss" in trying to get the Verbatim 43888 drive with the Pioneer hardware, but I just wanted to let people know that today, April 9, 2025, Amazon sent me a Verbatim drive with the following:
OS device name: F:
Revision: 1.05
Yes, you have the BU40N. There are no more 43888's containing Pioneer drives. They are all now containing LG BU40N drives inside.
Infexshun
#6 Post by Infexshun » Sat Apr 12, 2025 7:57 pm
Mine arrived yesterday. Same thing. BU40N. I thought I'd researched it well, but I hadn't come across this site yet. That said, flashing the drive with the 1.03 here I was able to get it working yesterday. However, I thought I'd give you a heads up in advance. I had so much trouble today with hash errors. Turns out the drive is insanely sensitive to wobble. Since it was vibrating through my desk yesterday, I put a soft, neatly folded rag under it today to quiet it down. Tried some new discs and kept getting those hash errors. Eventually I came back to the discs that worked yesterday and even THEY too were getting those errors... The link here suggested the drive might be failing, but I eventually discovered removing the rag and putting directly on the desk again, suddenly the errors were gone. Keep in mind this was a very flat neatly folded rag with the same desk under it, but i guess it was just enough to screw it up. So. Make sure to place it on a hard surface without padding.
WaitingForGuacamole
#7 Post by WaitingForGuacamole » Sun Apr 13, 2025 6:51 pm
Mine arrived today, also a BU40N, I used the SDF tool to write the 1.03MK firmware
mk-firmware-pack-20200720.zip -> /MK/old/HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin
I'm calling out the path here because I'd seen some threads that said install "1.03MK", and I've seen a couple of people asking where to find it. This worked first time for me.
I'm getting 6.0X speed with it, so very happy thus far.
dirkthedaring83
#8 Post by dirkthedaring83 » Sun Apr 13, 2025 10:31 pm
Where did you get the firmware and how did you upgrade?
#9 Post by dcoke22 » Mon Apr 14, 2025 4:05 am
dirkthedaring83 wrote: Sun Apr 13, 2025 10:31 pm Where did you get the firmware and how did you upgrade?
It is all in the Ultimate UHD Drives Flashing Guide.
mwjoh
#10 Post by mwjoh » Mon May 19, 2025 4:16 pm
Just received a 43888 with a BU40N drive as well. Used the SDFtool to flash the DE_LG_BU40N_1.03_MK.bin firmware straightaway and it successfully accessed a 4K UHD disc that my BP50BN40 (flashed to BP60NB10, per guidance) refused to do.
