LibreDrive for Pioneer drives
AirborneRadio
#1411 Post by AirborneRadio » Mon Apr 07, 2025 5:47 pm
Worked like a charm!
Thanks a ton for your help!
PeterMac
#1412 Post by PeterMac » Wed Apr 09, 2025 11:22 am
Any chance for UHD BD in this old BDR-207EBK :) ? but guess it's too old
Zrzut ekranu 2025-04-09 131350.png (27.62 KiB) Viewed 17763 times
#1413 Post by Coopervid » Wed Apr 09, 2025 1:08 pm
PeterMac wrote: Wed Apr 09, 2025 11:22 am Any chance for UHD BD in this old BDR-207EBK :) ? but guess it's too old
No. First drive flashable is a 208.
skyseer
#1414 Post by skyseer » Thu Apr 10, 2025 3:23 pm
Is it possible for me to backup UHD discs with the following drive?
Drive informatie
Naam OS-apparaat: I:
Fabrikant: ASUS
Product: BW-16D1X-U
Revisie: E113
Serienummer: ...
Firmware datum: 2020-07-21
Bus encryptie flags: 1B
Firmware version: ID76
PeterMac
#1415 Post by PeterMac » Thu Apr 10, 2025 6:40 pm
Zrzut ekranu 2025-04-10 193734.png (27.32 KiB) Viewed 17510 times
Any chance to downgrade to 1.03 ?
zittrig
#1416 Post by zittrig » Thu Apr 10, 2025 7:12 pm
No, sorry. The firmware is newer then November 2022. All Pioneer drives which could be 4k friendly with the right firmware but were flashed to a firmware 12/22 or newer are out of the game.
skyseer
#1417 Post by skyseer » Thu Apr 10, 2025 7:24 pm
My firmware says 2020-07-21 as its date. So i should be good?
I'm sorry, i've tried to read up about it today but there is so much info, i am at a bit of a loss currently.
#1418 Post by Coopervid » Thu Apr 10, 2025 9:35 pm
skyseer wrote: Thu Apr 10, 2025 7:24 pm My firmware says 2020-07-21 as its date. So i should be good?
Post your Makemkv info.
skyseer
#1419 Post by skyseer » Thu Apr 10, 2025 10:40 pm
Drive informatie
Fabrikant: ASUS
Product: BW-16D1X-U
Revisie: E113
Serienummer: ...
#1420 Post by Billycar11 » Thu Apr 10, 2025 11:35 pm
PeterMac wrote: Thu Apr 10, 2025 6:40 pm Zrzut ekranu 2025-04-10 193734.png
come on peter you have been messaging me and asmcom for weeks then you buy this you knew this would be the case your are out of luck for now
it will happen eventually but not today
#1421 Post by Coopervid » Fri Apr 11, 2025 9:14 am
skyseer wrote: Thu Apr 10, 2025 10:40 pm Drive informatie
Fabrikant: ASUS
Product: BW-16D1X-U
Revisie: E113
Serienummer: ...
PM sent.
Lynx27
#1422 Post by Lynx27 » Fri Apr 11, 2025 9:24 am
Coopervid wrote: Fri Mar 28, 2025 7:54 pm
Lynx27 wrote: Fri Mar 28, 2025 11:27 am Hi, is it possible to enable UHD blu ray flashing on:
Manufacturer: ASUS
Product: SBC-06D2X-U
Revision: 1.10
Firmware date: 2017-04-18
Drive platform: Pioneer RS8590
Firmware version: ID22
If so how can this be done?
PM sent.
Thank you, however I tried to flash it and I'm getting:
Drive and firmware hardware types don't match.
#1423 Post by MartyMcNuts » Fri Apr 11, 2025 10:24 am
Lynx27 wrote: Fri Apr 11, 2025 9:24 am
Manufacturer: ASUS
Revision: 1.10
PM sent.
Make sure you check the "Force Flash" box.
#1424 Post by Coopervid » Fri Apr 11, 2025 10:39 am
Manufacturer: ASUS
Revision: 1.10
PM sent.
Sorry. I just learned a few days ago that the RS859x firmware belongs to a BD combo and not a BD writer (RS851x). So your drive can't be flashed. Only writers can be flashed for reading UHDs.
Lynx27
#1425 Post by Lynx27 » Fri Apr 11, 2025 11:34 am
Coopervid wrote: Fri Apr 11, 2025 10:39 am
PM sent.
Ok, Thank you anyway :)
What drive would you'd recommend I get for best compatibility?
