LibreDrive for Pioneer drives
AirborneRadio
Worked like a charm!
Thanks a ton for your help!
Any chance for UHD BD in this old BDR-207EBK
? but guess it's too old
No. First drive flashable is a 208.PeterMac wrote: Wed Apr 09, 2025 11:22 am Any chance for UHD BD in this old BDR-207EBK? but guess it's too old
Is it possible for me to backup UHD discs with the following drive?
Drive informatie
Naam OS-apparaat: I:
Fabrikant: ASUS
Product: BW-16D1X-U
Revisie: E113
Serienummer: ...
Firmware datum: 2020-07-21
Bus encryptie flags: 1B
Firmware version: ID76
Any chance to downgrade to 1.03 ?
No, sorry. The firmware is newer then November 2022. All Pioneer drives which could be 4k friendly with the right firmware but were flashed to a firmware 12/22 or newer are out of the game.
My firmware says 2020-07-21 as its date. So i should be good?
I'm sorry, i've tried to read up about it today but there is so much info, i am at a bit of a loss currently.
Post your Makemkv info.skyseer wrote: Thu Apr 10, 2025 7:24 pm My firmware says 2020-07-21 as its date. So i should be good?
Drive informatie
Fabrikant: ASUS
Product: BW-16D1X-U
Revisie: E113
Serienummer: ...
Fabrikant: ASUS
Product: BW-16D1X-U
Revisie: E113
Serienummer: ...
come on peter you have been messaging me and asmcom for weeks then you buy this you knew this would be the case your are out of luck for nowPeterMac wrote: Thu Apr 10, 2025 6:40 pm Zrzut ekranu 2025-04-10 193734.png
it will happen eventually but not today
PM sent.skyseer wrote: Thu Apr 10, 2025 10:40 pm Drive informatie
Fabrikant: ASUS
Product: BW-16D1X-U
Revisie: E113
Serienummer: ...
Thank you, however I tried to flash it and I'm getting:Coopervid wrote: Fri Mar 28, 2025 7:54 pmPM sent.Lynx27 wrote: Fri Mar 28, 2025 11:27 am Hi, is it possible to enable UHD blu ray flashing on:If so how can this be done?Code: Select all
Manufacturer: ASUS Product: SBC-06D2X-U Revision: 1.10 Firmware date: 2017-04-18 Bus encryption flags: 1B LibreDrive Information Status: Possible, not yet enabled Drive platform: Pioneer RS8590 Firmware version: ID22
Drive and firmware hardware types don't match.-
Make sure you check the "Force Flash" box.Lynx27 wrote: Fri Apr 11, 2025 9:24 amThank you, however I tried to flash it and I'm getting:Coopervid wrote: Fri Mar 28, 2025 7:54 pmPM sent.Lynx27 wrote: Fri Mar 28, 2025 11:27 am Hi, is it possible to enable UHD blu ray flashing on:If so how can this be done?Code: Select all
Manufacturer: ASUS Product: SBC-06D2X-U Revision: 1.10 Firmware date: 2017-04-18 Bus encryption flags: 1B LibreDrive Information Status: Possible, not yet enabled Drive platform: Pioneer RS8590 Firmware version: ID22Code: Select all
Sorry. I just learned a few days ago that the RS859x firmware belongs to a BD combo and not a BD writer (RS851x). So your drive can't be flashed. Only writers can be flashed for reading UHDs.Lynx27 wrote: Fri Apr 11, 2025 9:24 amThank you, however I tried to flash it and I'm getting:Coopervid wrote: Fri Mar 28, 2025 7:54 pmPM sent.Lynx27 wrote: Fri Mar 28, 2025 11:27 am Hi, is it possible to enable UHD blu ray flashing on:If so how can this be done?Code: Select all
Ok, Thank you anywayCoopervid wrote: Fri Apr 11, 2025 10:39 amSorry. I just learned a few days ago that the RS859x firmware belongs to a BD combo and not a BD writer (RS851x). So your drive can't be flashed. Only writers can be flashed for reading UHDs.Lynx27 wrote: Fri Apr 11, 2025 9:24 amThank you, however I tried to flash it and I'm getting:Code: Select all
What drive would you'd recommend I get for best compatibility?
