Pioneer BDR-UD03 UHD possibility
jws73
Re: Pioneer BDR-UD03 UHD possibility
Hi Coopervid
I also have the BDR-UD03 and would love your help. My info is the following:
OS device name: E:
Manufacturer: PIONEER
Product: BD-RW BDR-UD03
Revision: 1.11
Serial number: SCDL217091WL
Firmware date: 2018-11-28
Drive platform: RS8511
Firmware version: 1.11
Thank you!
OS device name: E:
Revision: 1.11
Thank you!
PM sent.jws73 wrote: Wed Apr 09, 2025 1:24 am Hi Coopervid
OS device name: E:
Revision: 1.11
Thank you!
Supcool
Hi Everyone
I also got BDR-UD03 and is also interested if it possible for it to read uhd disks
Here info about my current drive
OS device name: E:
Revision: 1.14
Serial number: [redacted]
Firmware date: 2020-06-15
Highest AACS version: 70
Firmware version: 1.14
Thank you by the way for anyone who tries to help
OS device name: E:
Revision: 1.14
sure email me see email belowSupcool wrote: Sat Apr 12, 2025 4:49 am Hi Everyone
OS device name: E:
Revision: 1.14
Supcool
Already sent you a email thank youBillycar11 wrote: Sat Apr 12, 2025 8:12 amsure email me see email belowSupcool wrote: Sat Apr 12, 2025 4:49 am Hi Everyone
OS device name: E:
Revision: 1.14
Litzner
I have 2 of these drivers.
Are these flash-able?
Revision: 1.14
Serial number: ...
Revision: 1.14
Serial number: ...
Yeah send me an email for the flasher see belowLitzner wrote: Sun Apr 13, 2025 6:05 pm I have 2 of these drivers.
Drive Information OS device name: D: Manufacturer: PIONEER Product: BD-RW BDR-UD03 Revision: 1.14 Serial number: ... Firmware date: 2020-06-15 Bus encryption flags: 1B LibreDrive Information Status: Enabled Drive platform: RS8511 Firmware name: PIONEER BDR-US03 Firmware type: Original (unpatched) Firmware version: 1.14 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: YesAre these flash-able?Code: Select all
Supcool
Just replied check your emailSupcool wrote: Sat Apr 12, 2025 9:21 amAlready sent you a email thank youBillycar11 wrote: Sat Apr 12, 2025 8:12 amsure email me see email belowSupcool wrote: Sat Apr 12, 2025 4:49 am Hi Everyone
OS device name: E:
Revision: 1.14
pyramid4045
Hi Coopervid
OS device name: G:
Revision: 1.21
Serial number: ...
Firmware date: 2018-04-26
Highest AACS version: 81
Firmware version: ID19
Thank you!
OS device name: G:
Revision: 1.21
Serial number: ...
Thank you!
sanjay
Hello Coopervid,
I thought I will try my luck with the local staples that had some Verbatim 43890.
I thought perhaps they might have some old stock.
I was right, I just picked one up and it's showing as Pioneer UD03
It would be great if you can help me also as you have helped so many with flashing this drive.
I will be checking for a PM.
Thanks,
very much
Thanks,
very much
Check your PM.pyramid4045 wrote: Mon Apr 21, 2025 3:02 pm Hi Coopervid
OS device name: G:
Revision: 1.21
Serial number: ...
Thank you!
Check your PM.sanjay wrote: Wed Apr 23, 2025 1:41 am Hello Coopervid,
Thanks,
very much
artvandelay
Hello!
I was just about to buy a new drive and then stumbled onto this thread, which suggests that I can make my BDR-UD03 read UHD discs. Is this possible? I am a Mac user.
Revision: 1.14
Serial number:
Highest AACS version: 19
You need a Windows PC or a good Windows VM to flash your drive. let me know.artvandelay wrote: Wed Apr 23, 2025 12:51 pm Hello!
Revision: 1.14
Serial number:
artvandelay
That's fine, I have access to a Windows PC
