Pioneer BDR-XS08MB-S flashable?
Zerlight
#1 Post by Zerlight » Tue Apr 08, 2025 9:25 am
Hi there, I'm a newbie to this forum and got my first BD drive. Just downloaded MakeMKV and discovered that LibreDrive is not enabled. I have read the threads on Pioneer drives and surprisingly found out that I got a drive comes with a firmware before Dec. 2022. There are very few people discussing this optical drive, so I wanted to double check that if there is any possibility of flashing it or rip using it.
Below is my MakeMKV info:
Manufacturer: PIONEER
Product: BD-RW BDR-XS08U
Revision: 1.00
Serial number: BJDL000476JP
Firmware date: 2022-10-11
Drive platform: Pioneer RS9621
Firmware version: ID69
Thank you a lot!
Re: Pioneer BDR-XS08MB-S flashable?
#2 Post by Coopervid » Tue Apr 08, 2025 6:55 pm
Zerlight wrote: Tue Apr 08, 2025 9:25 am Hi there, I'm a newbie to this forum and got my first BD drive. Just downloaded MakeMKV and discovered that LibreDrive is not enabled. I have read the threads on Pioneer drives and surprisingly found out that I got a drive comes with a firmware before Dec. 2022. There are very few people discussing this optical drive, so I wanted to double check that if there is any possibility of flashing it or rip using it.
Revision: 1.00
Thank you a lot!
There were some few other guys with this drive. Basically it would need Mike's attention and he has a little proggie to download your firmware to his server to make libredrive available. This has not happened and he never reacted to the posts of the other users with this drive. Sorry.
Zerlight
#3 Post by Zerlight » Wed Apr 09, 2025 7:04 am
Coopervid wrote: Tue Apr 08, 2025 6:55 pm There were some few other guys with this drive. Basically it would need Mike's attention and he has a little proggie to download your firmware to his server to make libredrive available. This has not happened and he never reacted to the posts of the other users with this drive. Sorry.
Thank you for your reply. It's a great pity to hear that. Anyway still a good drive though. Will try to play UHD with older PC platforms.
#4 Post by MartyMcNuts » Thu Apr 10, 2025 1:05 am
Zerlight wrote: Wed Apr 09, 2025 7:04 am
Contact Mike Admin. He should be able to download the firmware from your drive and enable LibreDrive.
soulseeker
#5 Post by soulseeker » Tue Mar 17, 2026 5:51 am
Did your drive ever get libre support?
