Hello ,
with the help of this forum i have flashed a Bluray Drive from Amazon to UHD drive (libredrive).
so far , so good;
it became a bit loud, but that is acceptable;
today i have entered a Bluray ReWritable, but it seems drive is not capable of reading it;
had all sorts of problems under Linux (it would not even eject the BD-RE) and under Windows there is also error.
could this be related to the Flashing process or is the rather Drive rather bad?
thanks.
(flashed WH16NS60) won't read BD-RE?
kapqa
kapqa
Re: (flashed WH16NS60) won't read BD-RE?
the media is Maxell ReWritable BD-RE (25GB Single Layer , speed 1x-2x), brandnew.
(under windows) IT WOULD take a very long time (minutes) to eject disc, which is certainly not normal behaviour.
the drive originally is probably a WH16NS55,
thanks.
thanks.
If brand new there's nothing to read from this disc with Makemkv. Use Imgburn to format it and copy some stuff to it. Then check if you can read it in Windows Explorer.
Why are you trying to use MakeMKV with a blank writable disc?kapqa wrote: Mon Apr 07, 2025 8:37 am Hello ,
so far , so good;
thanks.
kapqa
why would i need to format BD-RE if its brandnew?
i download imgburn (not available for linux) but it would not allow for burning ISO (Device not ready - medium not present > although it is inserted and state: found: 1 BD-RE XL)
maybe it is just incompatible BD-RE;
can you help me to flash back to original firmware to see if this resolved?
thanks.
thanks.
kapqa
for reference post here info obtained via linux terminal,
maybe there are some error , though, because it states "DVD-RW DVD+RW wrtingin not supported"?
also linux program states "drive is empty" although BD-RE is clearly inserted.
cd-drive
cd-drive version 2.2.0 x86_64-pc-linux-gnu
Copyright (c) 2003-2005, 2007-2008, 2011-2015, 2017, 2025 R. Bernstein
This is free software; see the source for copying conditions.
There is NO warranty; not even for MERCHANTABILITY or FITNESS FOR A
PARTICULAR PURPOSE.
The driver selected is GNU/Linux
The default device for this driver is /dev/cdrom
Drivers available...
GNU/Linux ioctl and MMC driver
cdrdao (TOC) disk image driver
bin/cuesheet disk image driver
Nero NRG disk image driver
CD-ROM drive supports MMC 3
Drive: /dev/cdrom
Vendor : HL-DT-ST
Model : BD-RE WH16NS60
Revision : 1.02
Profile List Feature
Blu Ray BD-RE
Blu Ray BD-R random recording
Blu Ray BD-R sequential recording
Blu Ray BD-ROM
DVD+R Double Layer - DVD Recordable Double Layer
DVD+R - DVD Recordable
DVD+RW - DVD Rewritable
DVD-R - Double-layer Jump Recording
DVD-R - Double-Layer Sequential Recording
Re-recordable DVD using Sequential Recording
Re-recordable DVD using Restricted Overwrite
Re-writable DVD
Re-recordable DVD using Sequential recording
Read only DVD
CD-RW Re-writable Compact Disc capable
Write once Compact Disc capable
Read only Compact Disc capable
Core Feature
Morphing Feature
Operational Change Request/Notification supported
Synchronous GET EVENT/STATUS NOTIFICATION supported
Removable Medium Feature
Tray type loading mechanism
can eject the medium or magazine via the normal START/STOP command
can be locked into the Logical Unit
Write Protect Feature
Random Readable Feature
Multi-Read Feature
CD Read Feature
C2 Error pointers are supported
CD-Text is supported
DVD Read Feature
Random Writable Feature
Incremental Streaming Writable Feature
Formattable Feature
Management Ability of the Logical Unit/media system to provide an apparently defect-free space. Feature
Restricted Overwrite Feature
CD-RW CAV Write Feature
DVD+RW Feature
DVD+R Feature
Rigid Restricted Overwrite Feature
CD Track at Once Feature
CD Mastering (Session at Once) Feature
Hardware : CD-ROM or DVD
Can eject : Yes
Can close tray : Yes
Can disable manual eject : Yes
Can select juke-box disc : No
Can set drive speed : No
Can read multiple sessions (e.g. PhotoCD) : Yes
Can hard reset device : Yes
Reading....
Can read Mode 2 Form 1 : Yes
Can read Mode 2 Form 2 : Yes
Can read (S)VCD (i.e. Mode 2 Form 1/2) : Yes
Can read C2 Errors : Yes
Can read IRSC : Yes
Can read Media Channel Number (or UPC) : Yes
Can play audio : Yes
Can read CD-DA : Yes
Can read CD-R : Yes
Can read CD-RW : Yes
Can read DVD-ROM : Yes
Writing....
Can write CD-RW : Yes
Can write DVD-R : Yes
Can write DVD-RAM : Yes
Can write DVD-RW : No
Can write DVD+RW : No
kapqa
ok, so i was able to write data to BD-RE on a mac using another drive , which is a NS40 converted to NS60 (which consider the better drive, since it is much more silent).
to write to disc, had to use "DVD" structure, the other 3 would fail on program "burn" under macos.
so most probably got duped by amazon warehouse and buought a defective NS55; but since i could read 4K UHD disc , thought it is just fine; but it seems it cannot handle other media equally well;
when i now enter the written-to BD-RE into the NS55>NS60 the windows would complain "enter a disc"
All LG / ASUS drives tend to die early.
