LibreDrive Possible, not yet enabled
Mandar1jn
Post by Mandar1jn » Tue Mar 25, 2025 10:35 pm
I recently bought a verbatim 43888, specifically because I read everywhere that it didn't need to be flashed and worked out of the box on UHD dics.
However, it seems that mine does not. Under the heading "LibreDrive Information", it states "Possible, not yet enabled".
I was successfully able to back up a bluray disc, but not a uhd bluray disc.
The full info is:
Product: BD-RE BU40N
Revision: 1.05
Serial number: MO1OB1F0346
Highest AACS version: 66
The firmware data is weird, but I never flashed it and it came in a sealed box.
The first time I started MakeMKV it told me to send a dump to support@makemkv.com
I did this on the 12th of march, but got no reaction (not that I'm obligated to one)
Does this mean I do still need to flash it? And if so which specific firmware?
Re: LibreDrive Possible, not yet enabled
Post by Billycar11 » Tue Mar 25, 2025 10:45 pm
see guide below or email me or marty for an auto flasher
Post by MartyMcNuts » Tue Mar 25, 2025 10:54 pm
Mandar1jn wrote: Tue Mar 25, 2025 10:35 pm I recently bought a verbatim 43888, specifically because I read everywhere that it didn't need to be flashed and worked out of the box on UHD dics.
The full info is:
Revision: 1.05
That's no longer true as the Verbatim 43888 now comes with an LG BU40N inside. It can be flashed.
Mandar1jn
Post by Mandar1jn » Wed Mar 26, 2025 1:12 pm
Thank you for the advice and sorry for the confusion on my part. I have now flashed the drive and it works flawlessly
ufococoa
Post by ufococoa » Mon Apr 07, 2025 5:42 am
Hi all,
I have the same situation; it states that LibreDrive is possible, but not yet enabled. Is there any chance for me to get the drive to work with UHD discs?
OS device name: H:
Revision: 1.05
Serial number: MODP2FF4214
Highest AACS version: 76
Post by Billycar11 » Mon Apr 07, 2025 6:10 am
ufococoa wrote: Mon Apr 07, 2025 5:42 am Hi all,
OS device name: H:
Revision: 1.05
yeah see guide below or email me or Marty for an auto flasher email is below as well
