i've a problem with the german Version of Konklave. Maybe you can help me.
Dump was send.
Log-Message:
MakeMKV v1.17.8 win(x64-release) started
Using LibreDrive mode (v06.3 id=7FA2657C7667)
Saved AACS dump file as MKB20_v77_UHD_KNKL_4454.tgz
Product: BD-RE WH16NS60
Revision: 1.02
Highest AACS version: 81
Thanks,
maddes
Konklave German
keydb_helper
Re: Konklave German
Thank you for providing a suitable disc dump file.maddes22 wrote: Sat Apr 05, 2025 8:14 pm Hello,
Dump was send.
Thanks,
maddes
The 4454 variant of Konklave has been added to the public keydb.
If you haven't previously configured MakeMKV to utilise the public keydb you can follow my instructions here or use SamuriHL's utility for Windows (Link)
Public KeyDB Disc Submissions
maddes22
Re: Konklave German
It works now.
Many thanks !
Many thanks !
