Hello all! I need to RMA an LG BP60NB10 drive that I put patched firmware on. As I understand, if I send in the drive with the updated firmware, they may deny the RMA. I've been searching around here and on Google for a copy of the original firmware to flash back onto it, but haven't been able to find it anywhere. LG's website doesn't even list the model properly, so they don't have the firmware available. Does anyone have a copy of the stock BP60NB10 firmware, or can point me in the direction of where I could find it?
BP60NB10 Factory Firmware
Re: BP60NB10 Factory Firmware
Try the original LG Auto Updater.
It would be very helpful if you actually told us what firmware you put on it or posted the MakeMKV drive info & libredrive info sections!!Tyyrus wrote: Fri Apr 04, 2025 2:36 pm Hello all! I need to RMA an LG BP60NB10 drive that I put patched firmware on. As I understand, if I send in the drive with the updated firmware, they may deny the RMA. I've been searching around here and on Google for a copy of the original firmware to flash back onto it, but haven't been able to find it anywhere. LG's website doesn't even list the model properly, so they don't have the firmware available. Does anyone have a copy of the stock BP60NB10 firmware, or can point me in the direction of where I could find it?
A search for "original firmware flashers" will lead you to the thread I created ages ago: viewtopic.php?f=16&t=24443
They are old but they are the original LG flashers. Also, the BP60NB10 flasher would be for the SVC NB10, not the SVC NB12. Can't help you with the SVC NB12.
I think LG have software (or at least they used to) that you install which can update the firmware for you.
Hello, and thanks for replying! Sorry, obviously I should have posted that information. Currently, here is my info:MartyMcNuts wrote: Fri Apr 04, 2025 11:59 pm It would be very helpful if you actually told us what firmware you put on it or posted the MakeMKV drive info & libredrive info sections!!
Product: BD-RE BP60NB10
Revision: 1.02
Serial number: SIM04OAIC3047
Firmware date: 2121-07-08 15:56
Highest AACS version: 70
Firmware version: 1.02
I tried searching for the LG firmware downloader. The LG website itself doesn't have any downloads for the model that I could find. I did find a link to some files on the hitachi-lg site at https://hitachi-lg.com/en/support/firmw ... load/?v=11 but the firmware download link is broken and gives me a "file not found" error in Korean, and the "Auto Firmware Download" program just gives me a "This program can not run on your operating system" error (I'm on Windows 11). I tried running it in compatibility mode with a bunch of different older Windows versions but no luck.
If anyone has the SVC NB12 firmware, or a link to an updater that might work with that model, I'd really appreciate it. Thanks for the help!
Actually, I have got the orginal BP60NB10 NB12 1.02 firmware. Here you go. It's just the firmware file, no flasher but see if you can flash it to the drive using SDFTool Flasher.Tyyrus wrote: Sat Apr 05, 2025 3:14 amHello, and thanks for replying! Sorry, obviously I should have posted that information. Currently, here is my info:MartyMcNuts wrote: Fri Apr 04, 2025 11:59 pm It would be very helpful if you actually told us what firmware you put on it or posted the MakeMKV drive info & libredrive info sections!!
I had actually found that thread you linked and tried the flasher, but as you said it didn't work because I have the SVC NB12 model.Code: Select all
Drive Information OS device name: D: Manufacturer: HL-DT-ST Product: BD-RE BP60NB10 Revision: 1.02 Serial number: SIM04OAIC3047 Firmware date: 2121-07-08 15:56 Bus encryption flags: 17 Highest AACS version: 70 LibreDrive Information Status: Enabled Drive platform: MT1959 Firmware type: Patched (microcode access re-enabled) Firmware version: 1.02 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes No disc inserted
That worked perfectly, thank you so much for the file! And thanks for putting in so much work and information around here, your posts popped up everywhere during my search. I really appreciate it!MartyMcNuts wrote: Sat Apr 05, 2025 9:36 am
HL-DT-ST-BD-RE_BP60NB10-NB12-1.02-N000300-212107081556.bin.zip
You're welcome.Tyyrus wrote: Sat Apr 05, 2025 6:28 pmThat worked perfectly, thank you so much for the file! And thanks for putting in so much work and information around here, your posts popped up everywhere during my search. I really appreciate it!MartyMcNuts wrote: Sat Apr 05, 2025 9:36 am
