“Fatal Error Occured” with MacOS 15.4 Developer Beta 1
PapWV
Re: “Fatal Error Occured” with MacOS 15.4 Developer Beta 1
Post by PapWV » Sat Apr 05, 2025 9:55 pm
Same problem here with the older version. Upgraded to the latest for Mac/OS and now, after the disc scan, the read fails due to something it can't do while downloading Hash Keys (?). I guess this is just something to do with the decryption but wanted to see if anyone else is having the same issue.
By the way, this error is present on both my Mac mini and my son's Windows 11 computers.
asr101
Post by asr101 » Sat Apr 05, 2025 10:28 pm
Thanks Mike for the fast fix (fixes :lol: )
Mart2025
Post by Mart2025 » Sat Apr 05, 2025 11:32 pm
Wow! Indeed, thanks Mike for the fast fix!
Flesh
Post by Flesh » Sun Apr 06, 2025 12:38 am
PapWV wrote: Sat Apr 05, 2025 9:55 pm Same problem here with the older version. Upgraded to the latest for Mac/OS and now, after the disc scan, the read fails due to something it can't do while downloading Hash Keys (?). I guess this is just something to do with the decryption but wanted to see if anyone else is having the same issue.
Different issue - websites that host hashkeys is in Russia if not mistaken. If I remember the fix you might have to try using a different DNS or even a VPN if it is your provider blocking access.
iamaydo
Post by iamaydo » Sun Apr 06, 2025 12:43 am
Flesh wrote: Sun Apr 06, 2025 12:38 am
Since they're able to access the websites which host the keys then DNS is not the problem. DNS only points the device to the IP address.
It might be the keys are corrupt or have been tampered with, or a bug in decryption somewhere.
nicholfd
Post by nicholfd » Sun Apr 06, 2025 12:50 am
No - look at my post on the end of page 7 & Mike's post near the end of page 8. Affected both Windows & macOS.
Problem with the 1.18.0 release, now fixed with the 1.18.1 release.
Z4Devil
Post by Z4Devil » Sun Apr 06, 2025 8:19 am
mike admin wrote: Sat Apr 05, 2025 7:22 pm Bug was universal (
1.18.1 is out.
Thank you so much Mike - for the fast fixing and spending parts of the well deserved weekend for this.
Z4Devil
Post by Z4Devil » Sun Apr 06, 2025 8:27 am
dcoke22 wrote: Fri Apr 04, 2025 10:30 pm As a 27" iMac user, I somehow now own three Apple Silicon Macs and yet I still spend most of my time using my now ancient Intel based 27" iMac. Funny how the world works sometimes.
#1
Using the iMP with 18 core, I enjoy working with it much more than with my MBA M2 ;-) And: it is supported with the next 2 upcoming OS (after Sequoia) until 2027. A support period that Apple usually not provides, the iMP is the exception.
Jarek
Post by Jarek » Sun Apr 06, 2025 10:53 am
Hi
Now works perfect for ripping, but integration with VLC not working. Can you check this pls
Cuddy2977
Post by Cuddy2977 » Sun Apr 06, 2025 1:23 pm
1.18.1 is out.
Cheers, Mike: you and the team have done well!
The patch worked!
Cuddy2977
Post by Cuddy2977 » Sun Apr 06, 2025 1:33 pm
First things first?
A big thank you goes to Mike and the team: it looks like the 1.18.1 patch has worked.
At least, my 4k copy of Aliens has been ripped: and is now transcoding with HandBrake.
As a thought, though … ?
I have two models of the Pioneer BD-RW UD04 burner: an older Archgon model with version 1.11 of the firmware, and a newer, Verbatim 43888 branded one, with version 1.14.
The Verbatim model refused to do the rip: as “the volume key is unknown for this disc”.
The Archon one ripped it successfully.
I hope that helps Mike and the development team.
Screenshot 2025-04-06 at 12.46.14.png (593.48 KiB) Viewed 35803 times
Screenshot 2025-04-06 at 12.36.38 (Using Verbatime Drive).png (757.25 KiB) Viewed 35803 times
atl001
Post by atl001 » Sun Apr 06, 2025 5:27 pm
Thanks for the amazing turnaround on the MacOS 15.4 bugs!
Drew
htozaki
Post by htozaki » Mon Apr 07, 2025 9:36 am
Jarek wrote: Sun Apr 06, 2025 10:53 am Hi
I have no problem to see blu-ray in VLC. I just reinstall makemkv, do nothing for VLC.
Does those files under /Applications/VLC.app/Contents/MacOS/lib properly linked to the correct makemkv dylib?
% ls -l
total 2160
lrwxr-xr-x  1 root     admin      56 Nov  7 12:27 libaacs.dylib -> /Applications/MakeMKV.app/Contents/lib/libmmbd_new.dylib
lrwxr-xr-x  1 root     admin      56 Nov  7 12:28 libbdplus.dylib -> /Applications/MakeMKV.app/Contents/lib/libmmbd_new.dylib
lrwxr-xr-x  1 root     admin      56 Nov  7 12:28 libmmdb.dylib -> /Applications/MakeMKV.app/Contents/lib/libmmbd_new.dylib
Cuddy2977
Post by Cuddy2977 » Tue Apr 08, 2025 5:36 pm
I believe you need to toggle the relevant switch in Settings>Privacy and Security>App Management
(That’s where I got taken, when I ticked the relevant box in MakeMKV’s settings.)
Screenshot 2025-04-08 at 18.32.31.png (789.05 KiB) Viewed 35219 times
Jarek
Post by Jarek » Wed Apr 16, 2025 3:39 pm
htozaki wrote: Mon Apr 07, 2025 9:36 am
% ls -l
total 2160
Thank you :) now it works like a charm :)
