“Fatal Error Occured” with MacOS 15.4 Developer Beta 1
PapWV
Re: “Fatal Error Occured” with MacOS 15.4 Developer Beta 1
Same problem here with the older version. Upgraded to the latest for Mac/OS and now, after the disc scan, the read fails due to something it can't do while downloading Hash Keys (?). I guess this is just something to do with the decryption but wanted to see if anyone else is having the same issue.
By the way, this error is present on both my Mac mini and my son's Windows 11 computers.
asr101
Thanks Mike for the fast fix (fixes
Mart2025
Wow! Indeed, thanks Mike for the fast fix!
Flesh
Different issue - websites that host hashkeys is in Russia if not mistaken. If I remember the fix you might have to try using a different DNS or even a VPN if it is your provider blocking access.PapWV wrote: Sat Apr 05, 2025 9:55 pm Same problem here with the older version. Upgraded to the latest for Mac/OS and now, after the disc scan, the read fails due to something it can't do while downloading Hash Keys (?). I guess this is just something to do with the decryption but wanted to see if anyone else is having the same issue.
iamaydo
Since they're able to access the websites which host the keys then DNS is not the problem. DNS only points the device to the IP address.Flesh wrote: Sun Apr 06, 2025 12:38 amDifferent issue - websites that host hashkeys is in Russia if not mistaken. If I remember the fix you might have to try using a different DNS or even a VPN if it is your provider blocking access.PapWV wrote: Sat Apr 05, 2025 9:55 pm Same problem here with the older version. Upgraded to the latest for Mac/OS and now, after the disc scan, the read fails due to something it can't do while downloading Hash Keys (?). I guess this is just something to do with the decryption but wanted to see if anyone else is having the same issue.
It might be the keys are corrupt or have been tampered with, or a bug in decryption somewhere.
nicholfd
No - look at my post on the end of page 7 & Mike's post near the end of page 8. Affected both Windows & macOS.Flesh wrote: Sun Apr 06, 2025 12:38 amDifferent issue - websites that host hashkeys is in Russia if not mistaken. If I remember the fix you might have to try using a different DNS or even a VPN if it is your provider blocking access.PapWV wrote: Sat Apr 05, 2025 9:55 pm Same problem here with the older version. Upgraded to the latest for Mac/OS and now, after the disc scan, the read fails due to something it can't do while downloading Hash Keys (?). I guess this is just something to do with the decryption but wanted to see if anyone else is having the same issue.
Problem with the 1.18.0 release, now fixed with the 1.18.1 release.
For sale 4K UHD Flashed USB drives:
ASUS Slim, Buffalo Slim, LG Slim,
Buffalo 5 1/4", ASUS 5 1/4",
drives@nicholasfamilycentral.com
Z4Devil
Thank you so much Mike - for the fast fixing and spending parts of the well deserved weekend for this.
Z4Devil
#1dcoke22 wrote: Fri Apr 04, 2025 10:30 pm As a 27" iMac user, I somehow now own three Apple Silicon Macs and yet I still spend most of my time using my now ancient Intel based 27" iMac. Funny how the world works sometimes.
Using the iMP with 18 core, I enjoy working with it much more than with my MBA M2
Jarek
Hi
Now works perfect for ripping, but integration with VLC not working. Can you check this pls
Cuddy2977
Cheers, Mike: you and the team have done well!
The patch worked!
Cuddy2977
First things first?
A big thank you goes to Mike and the team: it looks like the 1.18.1 patch has worked.
At least, my 4k copy of Aliens has been ripped: and is now transcoding with HandBrake.
As a thought, though … ?
I have two models of the Pioneer BD-RW UD04 burner: an older Archgon model with version 1.11 of the firmware, and a newer, Verbatim 43888 branded one, with version 1.14.
The Verbatim model refused to do the rip: as “the volume key is unknown for this disc”.
The Archon one ripped it successfully.
I hope that helps Mike and the development team.
atl001
Thanks for the amazing turnaround on the MacOS 15.4 bugs!
Drew
Drew
htozaki
I have no problem to see blu-ray in VLC. I just reinstall makemkv, do nothing for VLC.Jarek wrote: Sun Apr 06, 2025 10:53 am Hi
Does those files under /Applications/VLC.app/Contents/MacOS/lib properly linked to the correct makemkv dylib?
% ls -l
total 2160
lrwxr-xr-x 1 root admin 56 Nov 7 12:27 libaacs.dylib -> /Applications/MakeMKV.app/Contents/lib/libmmbd_new.dylib
lrwxr-xr-x 1 root admin 56 Nov 7 12:28 libbdplus.dylib -> /Applications/MakeMKV.app/Contents/lib/libmmbd_new.dylib
lrwxr-xr-x 1 root admin 56 Nov 7 12:28 libmmdb.dylib -> /Applications/MakeMKV.app/Contents/lib/libmmbd_new.dylib
Cuddy2977
I believe you need to toggle the relevant switch in Settings>Privacy and Security>App ManagementJarek wrote: Sun Apr 06, 2025 10:53 am Hi
(That’s where I got taken, when I ticked the relevant box in MakeMKV’s settings.)
Jarek
Thank youhtozaki wrote: Mon Apr 07, 2025 9:36 amI have no problem to see blu-ray in VLC. I just reinstall makemkv, do nothing for VLC.Jarek wrote: Sun Apr 06, 2025 10:53 am Hi
Does those files under /Applications/VLC.app/Contents/MacOS/lib properly linked to the correct makemkv dylib?Code: Select all
% ls -l total 2160 lrwxr-xr-x 1 root admin 56 Nov 7 12:27 libaacs.dylib -> /Applications/MakeMKV.app/Contents/lib/libmmbd_new.dylib lrwxr-xr-x 1 root admin 56 Nov 7 12:28 libbdplus.dylib -> /Applications/MakeMKV.app/Contents/lib/libmmbd_new.dylib lrwxr-xr-x 1 root admin 56 Nov 7 12:28 libmmdb.dylib -> /Applications/MakeMKV.app/Contents/lib/libmmbd_new.dylib
