Hi all,
It seems like that I should post dump file here.
[SOLVED]DUMP SUBMISSION-I can't decrypt AACS v82 Blu-ray Disc 3C58
DoctorCici
Re: DUMP SUBMISSION-I can't decrypt AACS v82 Blu-ray Disc 3C58
You should also email it to svq@makemkv.com.
DoctorCici
Oh, thanks. I'll do it later.
DoctorCici
I just installed the 1.1.8 version. But during the decryption process, MakeMKV stopped working and a popup message saying "Fatal error occurred, program will now exit" showed up (you can see the screenshot in the attachment), then the program exited. Any suggestion to this situation?
Re: DUMP SUBMISSION-I still can't decrypt AACS v82 Blu-ray Disc 3C58
Try going back to the previous version of MakeMKV you were using. https://makemkv.com/download/old/
There seems to be a bug in the 1.18.0 version of MakeMKV.
DoctorCici
If I installed the 1.17.9 version, can I decrypt AACS v82 Blu-ray disc ? Or I have to wait for a new version of MakeMKV?dcoke22 wrote: Sat Apr 05, 2025 12:50 pm Try going back to the previous version of MakeMKV you were using. https://makemkv.com/download/old/
That's a complication. In a different post, the author of MakeMKV stated that even with 1.18.0, people would need to submit dumps to svq@makemkv.com, at least for a little bit. https://forum.makemkv.com/forum/viewtopic.php?p=172232#p172232DoctorCici wrote: Sat Apr 05, 2025 12:57 pmIf I installed the 1.17.9 version, can I decrypt AACS v82 Blu-ray disc ? Or I have to wait for a new version of MakeMKV?dcoke22 wrote: Sat Apr 05, 2025 12:50 pm Try going back to the previous version of MakeMKV you were using. https://makemkv.com/download/old/
Assuming you've submitted that dump, eventually a key will be available either with MakeMKV's internal key system where it downloads keys as needed or in the public keydb.cfg. Once a key is available I would expect 1.17.9 to work. If whatever is causing failures with 1.18.0 is fixed before a key is available, then I would say move to that version.
DoctorCici
Problem solved! I didn't know where to put the keydb.cfg file when I tried last time. Now the 1.17.9 version is working. Thank you for the information!dcoke22 wrote: Sat Apr 05, 2025 1:24 pmThat's a complication. In a different post, the author of MakeMKV stated that even with 1.18.0, people would need to submit dumps to svq@makemkv.com, at least for a little bit. https://forum.makemkv.com/forum/viewtopic.php?p=172232#p172232DoctorCici wrote: Sat Apr 05, 2025 12:57 pmIf I installed the 1.17.9 version, can I decrypt AACS v82 Blu-ray disc ? Or I have to wait for a new version of MakeMKV?dcoke22 wrote: Sat Apr 05, 2025 12:50 pm Try going back to the previous version of MakeMKV you were using. https://makemkv.com/download/old/
