The AACS v82 Blu-ray disc still does not work with MakeMKV
sumaho
#1 Post by sumaho » Sat Apr 05, 2025 1:53 am
I have installed version 1.18.0 and saved the keydb.cfg file in the .makemkv folder using FindVUK. However, the process stops due to AACS issues. The dump file is not generated either. Is there any other solution?
Re: The AACS v82 Blu-ray disc still does not work with MakeMKV
#2 Post by MartyMcNuts » Sat Apr 05, 2025 4:38 am
sumaho wrote: Sat Apr 05, 2025 1:53 am I have installed version 1.18.0 and saved the keydb.cfg file in the .makemkv folder using FindVUK. However, the process stops due to AACS issues. The dump file is not generated either. Is there any other solution?
Read this: viewtopic.php?f=8&t=37493
sumaho
#3 Post by sumaho » Sat Apr 05, 2025 8:07 am
Yes, I am aware of that. I updated to version 1.18.0 and installed it, but it still didn't work, which is why I wrote this post.
sumaho
#4 Post by sumaho » Sat Apr 05, 2025 8:08 am
MartyMcNuts wrote: Sat Apr 05, 2025 4:38 am
#5 Post by mike admin » Sat Apr 05, 2025 8:45 am
sumaho wrote: Sat Apr 05, 2025 8:08 am Yes, I am aware of that. I updated to version 1.18.0 and installed it, but it still didn't work, which is why I wrote this post.
For a bit, you still have to submit dumps for v82, same way as with UHD.
