The AACS v82 Blu-ray disc still does not work with MakeMKV
sumaho
Post by sumaho »
I have installed version 1.18.0 and saved the keydb.cfg file in the .makemkv folder using FindVUK. However, the process stops due to AACS issues. The dump file is not generated either. Is there any other solution?
Re: The AACS v82 Blu-ray disc still does not work with MakeMKV
sumaho wrote: Sat Apr 05, 2025 1:53 am I have installed version 1.18.0 and saved the keydb.cfg file in the .makemkv folder using FindVUK. However, the process stops due to AACS issues. The dump file is not generated either. Is there any other solution?
Read this: viewtopic.php?f=8&t=37493
sumaho
Post by sumaho »
Yes, I am aware of that. I updated to version 1.18.0 and installed it, but it still didn't work, which is why I wrote this post.
sumaho
Post by sumaho »
MartyMcNuts wrote: Sat Apr 05, 2025 4:38 am
Post by mike admin »
sumaho wrote: Sat Apr 05, 2025 8:08 am Yes, I am aware of that. I updated to version 1.18.0 and installed it, but it still didn't work, which is why I wrote this post.
For a bit, you still have to submit dumps for v82, same way as with UHD.
