CharlyTheSneaky
#2851 Post by CharlyTheSneaky » Fri Apr 04, 2025 2:41 pm
Coopervid wrote: Fri Apr 04, 2025 2:24 pm Let me know your country of residence. You will then receive a PM.
Hey there,
I'm French,
#2852 Post by Coopervid » Fri Apr 04, 2025 3:40 pm
CharlyTheSneaky wrote: Fri Apr 04, 2025 2:41 pm
Hey there,
I'm French,
PM sent.
GlossedOver
#2853 Post by GlossedOver » Fri Apr 04, 2025 5:30 pm
Thanks for the info everyone, I ended up finding a different device that at least has the original unpatched firmware. Was wondering if it can do UHD as well?
Manufacturer: PIONEER
Product: BD-RW BDR-XD05
Revision: 3.10
Serial number: ...
Firmware date: 2017-06-22
Drive platform: RS8232
Firmware name: PIONEER BDR-XD05
Firmware version: 3.10/ID34
#2854 Post by dcoke22 » Fri Apr 04, 2025 7:03 pm
CharlyTheSneaky wrote: Fri Apr 04, 2025 1:45 pm
dcoke22 wrote: Fri Apr 04, 2025 1:01 pm
If the Pioneer drives are new, then they will almost assuredly come with firmware that's too new to support LibreDrive and thus they won't be able to rip 4K UHDs.
I was mainly saying that *people* said the drives were "too new" if I buy from Amazon there is no way of knowing if it will be ripable?
Are ALL Pioneer drives (still) affected by this Feb 23 driver updates? Are there any none affected?
dcoke22 wrote: Fri Apr 04, 2025 1:01 pm The easiest way to get a new Pioneer drive with older, compatible firmware is to buy from a seller, Asmcom in the case of Europe.
I will look into this thoroughly thank you!
Also one last question, there is no way to know if a drive is ripable unless it's bought from a trusted source or in your hands right?
Thanks for clearing up a few things,
It is my understanding that it is all Pioneer drives that are affected. If you buy a new Pioneer drive from pretty much any retail shop, it'll come with the new firmware. It has been long enough that all the old stock is gone.
You have to either get a drive from a trusted source or have some way to verify the firmware level.
nukmasta
#2855 Post by nukmasta » Fri Apr 04, 2025 8:09 pm
Buffalo BRUHD-PU3-BK
Hi all, I think I need to Flash to an LG drive and THEN to BU40N as I have the BU14?
I try and flash with this:
But I get this:
What am I missing here?
#2856 Post by MartyMcNuts » Fri Apr 04, 2025 11:52 pm
nukmasta wrote: Fri Apr 04, 2025 8:09 pm Buffalo BRUHD-PU3-BK
But I get this:
Ensure there is no disc in the drive and the tray is closed.
nukmasta
#2857 Post by nukmasta » Sat Apr 05, 2025 4:14 am
MartyMcNuts wrote: Fri Apr 04, 2025 11:52 pm
But I get this:
Yup I had a disc in im a dummy. Thank you for your response and all that you do Marty! It worked! Is that all I need to do? Done deal now? I saw other threads about putting back the Buffalo/BU40N FW per instructions? What are the benefits of moving it back from the initial flash?
EDIT: I took a chance and recovered to BU10 from the ultimate drive pack. If I understand correctly, the .mk FW is only to unlock Libre. To get full features of the drive you need to flash back to the FW. Correct me if im wrong!!!
If anyone comes across this in 2025 for a Buffalo BRUHD-PU3-BK straight from Japan here is how to unlock your UHD drive in 3 easy steps:
-Download Flash tool + Ultimate FW pack.
-WRITE the DE_LG_BU40N_1.03_MK FW to the drive (Ensure no disc is in the drive or its open)
-RECOVER the drive to DE_Buffalo_BRUHD-PU3_BU10 (Ensure to pick DE_LG_BU40N_1.03_MK first as existing driver. THEN pick DE_Buffalo_BRUHD-PU3_BU10 second)
kapqa
#2858 Post by kapqa » Mon Apr 07, 2025 5:31 pm
the pionieer drives with "bluray-ultraHD" label on it, are those already "libredrive" and work out of box with make-mkv?
thanks.
#2859 Post by Coopervid » Mon Apr 07, 2025 6:28 pm
kapqa wrote: Mon Apr 07, 2025 5:31 pm the pionieer drives with "bluray-ultraHD" label on it, are those already "libredrive" and work out of box with make-mkv?
thanks.
No, not anymore since Dec. 2022. Tell me your country of residence for "Pioneer options".
kapqa
#2860 Post by kapqa » Mon Apr 07, 2025 6:50 pm
IT
#2861 Post by Coopervid » Mon Apr 07, 2025 6:57 pm
kapqa wrote: Mon Apr 07, 2025 6:50 pmIT
PM sent.
havok2022
#2862 Post by havok2022 » Fri Apr 11, 2025 1:49 am
Looking for a new drive that can ideally rip 4K UHD BRDs, and I need an external option ideally with USB and possibly eSATA as well. USB is a bit of a must though. I'm located in the US. It didn't seem like any of the inventory in the original post were external.
#2863 Post by MartyMcNuts » Fri Apr 11, 2025 3:01 am
havok2022 wrote: Fri Apr 11, 2025 1:49 am Looking for a new drive that can ideally rip 4K UHD BRDs, and I need an external option ideally with USB and possibly eSATA as well. USB is a bit of a must though. I'm located in the US. It didn't seem like any of the inventory in the original post were external.
Use an enclosure or SATA to USB powered adapter to use the internal desktop drives externally.
CharlyTheSneaky
#2864 Post by CharlyTheSneaky » Fri Apr 11, 2025 3:47 pm
Coopervid wrote: Fri Apr 04, 2025 3:40 pm
Hey there,
I'm French,
PM sent.
Hey man, I just received it, it can read CDs, DVDs and Blu-Ray correctly but it can't do 4K
Here are all of the specs :
OS device name: XX
Product: BD-RW BDR-UD03
Revision: 1.14
Serial number: XXXXXXXXXXXXXX
Firmware date: 2020-06-15
Highest AACS version: 47
Drive platform: RS8511
Firmware version: 1.14
Thanks a lot again!
cdbruce1973
Trouble Flashing New Drive on Linux
#2865 Post by cdbruce1973 » Fri Apr 11, 2025 3:52 pm
I am on Ubuntu 24.04, just installed a BU40N ultra slim internal drive.
I am following the guide to the letter, googled and found several things to try, etc. but no matter what I do differently I always end up with the same error:
Input file not found -- /tmp/HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin
Internal error 0x83000001
Notes:
  • I am logged in as ROOT
  • I gave full access (CHMOD 777) to the sdf.bin and the HL-DT ... bin files
  • I have tried both of the commands below:
    makemkvcon f -d 'dev_21:1' -f /tmp/sdf.bin rawflash enc -i /tmp/HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin
    makemkvcon f -d 'dev_21:1' -f /tmp/sdf.bin rawflash main -i /tmp/HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin
Any help would be greatly appreciated.
Info from MakeMKV:
OS device name: /dev/sr0
Product: BD-RE BU40N
Revision: 1.02
Serial number: ,,,
Bus encryption flags: 1F
Highest AACS version: 65
Harware support: Yes
Firmware support: No
Firmware version: 1.02
