The AACS v82 Blu-ray disc still does not work with MakeMKV
sumaho
I have installed version 1.18.0 and saved the keydb.cfg file in the .makemkv folder using FindVUK. However, the process stops due to AACS issues. The dump file is not generated either. Is there any other solution?
Re: The AACS v82 Blu-ray disc still does not work with MakeMKV
Read this: viewtopic.php?f=8&t=37493sumaho wrote: Sat Apr 05, 2025 1:53 am I have installed version 1.18.0 and saved the keydb.cfg file in the .makemkv folder using FindVUK. However, the process stops due to AACS issues. The dump file is not generated either. Is there any other solution?
sumaho
Yes, I am aware of that. I updated to version 1.18.0 and installed it, but it still didn't work, which is why I wrote this post.
sumaho
Yes, I am aware of that. I updated to version 1.18.0 and installed it, but it still didn't work, which is why I wrote this post.MartyMcNuts wrote: Sat Apr 05, 2025 4:38 amRead this: viewtopic.php?f=8&t=37493sumaho wrote: Sat Apr 05, 2025 1:53 am I have installed version 1.18.0 and saved the keydb.cfg file in the .makemkv folder using FindVUK. However, the process stops due to AACS issues. The dump file is not generated either. Is there any other solution?
For a bit, you still have to submit dumps for v82, same way as with UHD.sumaho wrote: Sat Apr 05, 2025 8:08 am Yes, I am aware of that. I updated to version 1.18.0 and installed it, but it still didn't work, which is why I wrote this post.
