“Fatal Error Occured” with MacOS 15.4 Developer Beta 1
Cuddy2977
Re: “Fatal Error Occured” with MacOS 15.4 Developer Beta 1
#91 Post by Cuddy2977 » Fri Apr 04, 2025 5:10 pm
KENSAI wrote: Fri Apr 04, 2025 3:24 pm <stares at pile of discs that area yearning to be ripped>
<realizes all is not right with the world right now> :cry:
Frustrating, isn’t it … ?
Bassman
#92 Post by Bassman » Fri Apr 04, 2025 8:31 pm
Also waiting for an update running under MacOS 15.4 final since with Parallels Win 11 Pro the VM version is very slow and does not work properly :(
ChipGallo
#93 Post by ChipGallo » Fri Apr 04, 2025 8:42 pm
It's in the grand tradition of winter ending when I buy a new 40 lb sack of ice melt. There's a new Synology NAS sitting here waiting for the drives to arrive and I blithely update the Mac to 15.4. At least the Pioneer disc player (thanks Billy!) can rip to my backup MacBook Air until Makemkv gets fixed. Thanks for the future update(s)!
MikeDaWiz
#94 Post by MikeDaWiz » Fri Apr 04, 2025 9:27 pm
ChipGallo wrote: Fri Apr 04, 2025 8:42 pm At least the Pioneer disc player (thanks Billy!) can rip to my backup MacBook Air until Makemkv gets fixed.
This is my situation as well. The unfortunate thing is the only extra external drive I have to save the rips to (because my M2 MacBook Air has very little memory) is not USB 3.0. Transferring the files back to the main HD I use to save my rips takes longer to transfer. But hopefully that 15.4 update comes sooner then later.
Bassman
#95 Post by Bassman » Fri Apr 04, 2025 9:45 pm
ChipGallo wrote: Fri Apr 04, 2025 8:42 pm It's in the grand tradition of winter ending when I buy a new 40 lb sack of ice melt. There's a new Synology NAS sitting here waiting for the drives to arrive and I blithely update the Mac to 15.4. At least the Pioneer disc player (thanks Billy!) can rip to my backup MacBook Air until Makemkv gets fixed. Thanks for the future update(s)!
So you have a second Mac = MacBook Air with an older system version? What is your main device? MacMini M4? I have also a license for DVDFab but this isn't working at all with M1-M4 ;(
#96 Post by dcoke22 » Fri Apr 04, 2025 10:30 pm
As a 27" iMac user, I somehow now own three Apple Silicon Macs and yet I still spend most of my time using my now ancient Intel based 27" iMac. Funny how the world works sometimes.
Mart2025
#97 Post by Mart2025 » Fri Apr 04, 2025 11:11 pm
First post on this forum, apologies if there're guidelines I'm not following.
I just downloaded version 1.18.0 and I'm still getting the error message "Fatal Error Occured". However, instead of getting the error message as soon as MakeMKV opens, I'm getting it about halfway through the disc opening process. I tried multiple discs and the error persists. MakeMKV was working fine before updating to MacOS 15.4 earlier today.
I have purchased a MakeMKV license and my app is registered. I'm running the official version of MacOS 15.4.
Many thanks.
#98 Post by dcoke22 » Fri Apr 04, 2025 11:50 pm
Mart2025 wrote: Fri Apr 04, 2025 11:11 pm Hello,
Many thanks.
MacOS 15.4 has changes that cause a crash in MakeMKV version 1.17.x and below.
Do you have debug logging turned on? With 1.18.0 is there anything printed in the log?
Mart2025
#99 Post by Mart2025 » Sat Apr 05, 2025 12:22 am
dcoke22 wrote: Fri Apr 04, 2025 11:50 pm
Many thanks.
I turned it on after reading your post. I'm getting the following output:
Debug log started at Sat Apr 5 00:15:13 2025 , written by MakeMKV v1.18.0 darwin(arm64-release)
001005:0000 MakeMKV v1.18.0 darwin(arm64-release) started
001004:0000 Debug logging enabled, log will be saved as file:///Users/martin/MakeMKV_log.txt
Network access is ENABLED, CURL version 8.7.1/(SecureTransport) LibreSSL/3.3.6/1.64.0 (x86_64-apple-darwin24.0) , proxy server not set.
002010:0000 Optical drive "BD-RE PIONEER BD-RW BDR-UD04 1.14 DGDL539132WLd" opened in OS access mode.
SDF v098: PIONEER_BD-RW___BDR-UD04_1.14_DGDL539132WL
001003:0020 DEBUG: Code 0 at MFVZU]`}}RoOAtmDPy4f~^8q?:29395149
DEBUG: Code 0 at \E!2;tb~}(1>F=d}IXuvBQ7R.:29394367
001011:0000 Using LibreDrive mode (v01.0 id=489CDFD6D392)
DEBUG: Code 2147483648 at #O20#1ND[]$<@-%=:121265499
samboca
#100 Post by samboca » Sat Apr 05, 2025 12:50 am
Same issue. There's no much in the error log:
Debug log started at Sat Apr  5 00:48:33 2025 , written by MakeMKV v1.18.0 darwin(arm64-release)
001004:0000 Debug logging enabled, log will be saved as file:///Users/<user>/MakeMKV_log.txt
002010:0000 Optical drive "BD-RE HL-DT-ST BD-RE BP60NB10 1.02 SIM03L3395304d" opened in OS access mode.
SDF  v098: HL-DT-ST_BD-RE_BP60NB10_1.02_212005070935_SIM03L3395304
001011:0000 Using LibreDrive mode (v06.3 id=4C194CE2C4D1)
ChipGallo
#101 Post by ChipGallo » Sat Apr 05, 2025 1:01 am
Bassman wrote: Fri Apr 04, 2025 9:45 pm
Correct. I shoulda updated the MacBook Air first and checked FCP and MakeMKV functionality but noooo, jumped the gun and did the main machine first. Very excited to work on my first NAS and finally get everything in one system.
#102 Post by dcoke22 » Sat Apr 05, 2025 1:19 am
Mart2025 and samboca hit the same debug code before they crashed.
I suspect Mike will have to make another update, but I'm just speculating.
This post: https://forum.makemkv.com/forum/viewtopic.php?f=4&t=37526 suggests 1.18.0 works on regular blu-rays and just crashes on UHDs.
ChipGallo
#103 Post by ChipGallo » Sat Apr 05, 2025 1:43 am
yes, I updated to version 1.18.0 on MacOS 15.4 (24E248) and ran it against the Serenity UHD and it exited with the fatal error. My initial pass was with the internet access turned on and the entire computer rebooted.
htozaki
#104 Post by htozaki » Sat Apr 05, 2025 1:51 am
That debug code
appears also on blu-ray.
In 4K, the last error message on log is:
003338:0000 Downloading latest HK to /Users/<Users>/Library/MakeMKV ...
nicholfd
#105 Post by nicholfd » Sat Apr 05, 2025 2:30 am
Worked up until the point of actually opening the UHD disc. Attached are the drive details & a screenshot of where it died.
OS device name: /dev/rdisk14
Product: BD-RE BU40N
Revision: 1.04
Serial number: MZRJ74G1743
Firmware date: 2120-05-06 11:42
Highest AACS version: 78
Firmware version: 1.04
Disc Information
Label: PLANE
Timestamp: 2023-01-27 19:31:03
Protection: AACS2.0/C v77
Data capacity: 65.2 Gb
Disc type: BD-ROM UHD
Number of layers: 3
Bus encryption flags: 80
